whats the problem?
Old Jan 4, 2004 | 06:59 PM
TylerC's Avatar
Default whats the problem?
Recently I was driving my Integra and when i tried to shift from 3rd into 4th gear it wouldn't go into gear, after that my clutch pedal got really tight and the clutch pedal was then useless, And when I can actually get my car into gear it makes a whining sound. Does anyone have any idea what my problem is?
Modified by TylerC at 4:37 AM 1/5/2004
Modified by TylerC at 7:36 PM 1/5/2004
Old Jan 4, 2004 | 08:06 PM
SubieDude's Avatar
Default Re: whats the problem? (TylerC)
if its making that kinda noise i would say its your transmission
Old Jan 4, 2004 | 08:08 PM
vaporboy12's Avatar
you diff is probably toast.
Old Jan 5, 2004 | 10:32 AM
TylerC's Avatar
Default Re: (hksb18b)
the car drives, just can't use the clutch pedal cause it tightens up, and doesn't seem to engage at all.
Old Jan 5, 2004 | 12:39 PM
J-g-D-s-M-r's Avatar
clutch ready to go out??
Old Jan 5, 2004 | 12:47 PM
EL Vap133's Avatar
When was the last time you replaced your clutch?
Old Jan 5, 2004 | 12:52 PM
tumbleweed's Avatar
Is it that way in all gears now? If so then when you push your clutch pedal in does it do anything or does it just move and nothing happens? If so then your presure plate on you clutch is toast.
Old Jan 5, 2004 | 02:08 PM
TylerC's Avatar
Default Re: whats the problem? (tumbleweed)
Well when i push in the clutch pedal it's real tight and it doesn't work unless i **** with it a little bit. I've asked a few people i know and most say it could be the slave cylinder, or throw out bearing, any ideas?
Old Jan 11, 2004 | 09:24 PM
2camsaam's Avatar
bump.
check the master and slave cylinders first.
Old Jan 11, 2004 | 09:50 PM
mEr's Avatar
mEr
Default Re: whats the problem? (2camsaam)
id say throwout bearing, happened to me a while back!
good luck
Old Jan 13, 2004 | 01:25 PM
TylerC's Avatar
Default Re: whats the problem? (Gen2B16)
It ended up being the pressure plate, blew the **** out of it. Thanks for the input guys.
LS_VTECteggy
Dec 21, 2009 05:22 AM
Street Racer X
Sep 21, 2008 02:35 PM
98R-1144
May 12, 2007 09:39 AM
camera obscura
Apr 17, 2003 07:22 PM
hybrider
Aug 3, 2002 12:53 PM
