B18C Clutch Problems... Please Help
Old Aug 10, 2008 | 02:55 PM
ender214's Avatar
Default B18C Clutch Problems... Please Help
I recently bought a 98 DB8 with a B18C in it and it feels like the clutch isn't fully disengaging. When I am stopped and the car is in gear with the clutch is pressed down to the floor the car will shake as if it is trying to creep forward and when I am shifting I have to force the car in and out of gear. Now my question is, will bleeding the clutch line take car of this and if so does anyone know if gravity bleeding works or is it just easier to bleed it the old fashioned way? Thank you in advance.
Old Aug 10, 2008 | 06:10 PM
ender214's Avatar
Dont every one reply at once.
Old Aug 10, 2008 | 07:01 PM
RSX-R's Avatar
Default Re: (ender214)
i think bleeding the clutch will get rid of the problem.
last month, my brother's prelude had the same problem and we bled the clutch and it didn't work. but after a mechanic readjusted the clutch, we then bled it again and then the problem went away. The reason why the mechanic readjusted the clutch is because air kept gettin back into the system because of bad adjustment of the clutch. but if you dont have the clutch adjustment problem, then bleeding it should fix the problem.
Old Aug 11, 2008 | 02:41 AM
_decker's Avatar
Default Re: (RSX-R)
Try adjusting the clutch pedal
Old Aug 19, 2008 | 12:54 AM
ender214's Avatar
Thanks for your responses. The problem went away just as quickly as it showed up. I am still going to pull the tranny to find out what happend. Thanks again.
TigerLy
Jul 16, 2008 01:59 PM
A.E Motoring
Apr 2, 2006 05:30 PM
skrewdlude
Nov 3, 2003 06:55 AM
taytay333
Nov 21, 2001 12:58 PM
