ls/vtec....why plug oil passage?
Old Sep 10, 2004 | 11:24 AM
Slimm-rw-'s Avatar
I'm a Jackass
Default ls/vtec....why plug oil passage?
I'm preppeing the b16 head I have, and was following these directions
http://www.racingknowledge.org...D=245
and I want to know why its necessary to plug the "oil passage"....I've tapped the hole but am having trouble getting the plug to fit, and I'm abou to take it to a machine shop to have it milled flat, but it doesn't look like the passage really goes anywhere....does it really have to be plugged?
Old Sep 10, 2004 | 12:29 PM
legendboy's Avatar
Default Re: ls/vtec....why plug oil passage? (Slimm-rw-)
You should plug it because there is nothing on the block to carry the oil down. Also, the ls headgasket isn't setup for that paticular oil galley.
You need to use a straight flute tap or it won't thread down far enough. Also the set screw you use to plug it should be very small. I think mine was 3mm long.
Old Sep 10, 2004 | 12:36 PM
legendboy's Avatar
Default Re: ls/vtec....why plug oil passage? (legendboy)
oh, also use locktite on the set screw when you install it.
Old Sep 10, 2004 | 12:42 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
you need an 1/8 npt fitting and tap along with the supply line we sell the entire kit
Old Sep 10, 2004 | 04:30 PM
SprayinCX's Avatar
Default Re: ls/vtec....why plug oil passage? (HOOKUPS)
if i am not mistaking isn't that hole the oil feed for the regular vtec engines? since the ls isn't vtec the yuo cap the head then yuo run the external oil feed line.
Old Sep 10, 2004 | 08:04 PM
punkracer's Avatar
if u dont plug the hole you will create a hot spot and blow your headgasket make sure u use a LS head gastket too
Nisif
Sep 16, 2014 06:25 AM
NOOdS
13
Nov 28, 2011 02:56 PM
EDDIEONETIME
Feb 13, 2008 07:00 PM
MR. BAR
Sep 9, 2005 11:37 PM
johnzm
Dec 9, 2004 10:14 PM
