help with engine light
Old Sep 9, 2004 | 12:10 PM
h0tsihatch's Avatar
Default help with engine light
my car keeps giving me a code 14 which is the iacv so i changed it and it still throws the code. i checked the wiring still pops up and i reset the ecu so now im out of ideas the only thing that might be the problem is i have a stripped screw on my intake manifold would that throw the code???? any ideas???
Old Sep 9, 2004 | 02:38 PM
h0tsihatch's Avatar
Default Re: help with engine light (h0tsihatch)
bump
Old Sep 10, 2004 | 05:33 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h0tsihatch &raquo;</TD></TR><TR><TD CLASS="quote">... i checked the wiring...</TD></TR></TABLE>How did you check the wiring? Did you just look at the plug or did you verify power & continuity back to the ECU?
Old Sep 10, 2004 | 11:45 AM
h0tsihatch's Avatar
Default Re: help with engine light (JimBlake)
i just looked to make sure the wires were in the rite spots
bump
Old Sep 10, 2004 | 12:27 PM
JimBlake's Avatar
That's only the first step in checking the wiring. You probably have to get a multi-meter & a circuit drawing in order to get much farther. Could be a cut wire somewhere on the way back to the ECU. Those can be a real PITA to find.
Old Sep 11, 2004 | 10:54 PM
chrisCNL's Avatar
is this a swap or a stock engine setup?
Old Sep 12, 2004 | 08:07 AM
h0tsihatch's Avatar
Default Re: help with engine light (chrisCNL)
swap
bump
Old Sep 12, 2004 | 08:14 AM
rev-speed's Avatar
do u happen to have a swap in a obd2 car and is runing obd1?
Old Sep 12, 2004 | 08:23 AM
h0tsihatch's Avatar
Default Re: (4cylinder)
yea my car was obd2 and the motor i have now is obd1
Old Sep 12, 2004 | 08:30 AM
rev-speed's Avatar
when u start the car when its cold
does the rpm ever stay up then drop?
around 1500 then back to about 800 when warm up
Old Sep 12, 2004 | 09:01 AM
Koolaidalan's Avatar
bump
My car does this, what does that mean?
Old Sep 12, 2004 | 09:07 AM
rev-speed's Avatar
Default Re: (Koolaidalan)
if ur runing obd2-1 and ur car doesn t idle up then back down when warm ur iac valve it not wire rite and u need to repin it
i have the wireing
but if it does we need to look more into it
Old Sep 12, 2004 | 02:28 PM
h0tsihatch's Avatar
i just checked it drops but only to about 1250 not down to 800
bump
Old Sep 12, 2004 | 02:50 PM
rev-speed's Avatar
it drop to 1200 from 1500
Old Sep 12, 2004 | 02:52 PM
rev-speed's Avatar
if ur idle never drops under 1200 first u need to adjust the idle screw on the throttle body
Old Sep 12, 2004 | 05:50 PM
h0tsihatch's Avatar
that wont be the reason why my engine light is on right???
bump
Old Sep 12, 2004 | 08:55 PM
rev-speed's Avatar
no but it affects it
do this put ur obd2 ecu back in if the rpm goes up and down repeatly then we need to reroute ur iac wire.
did u cut the three wire iac plug and use two wire only 4 the obd1 iac valve?
if so all we need to do is repin it
Old Sep 14, 2004 | 07:59 AM
h0tsihatch's Avatar
yea the 3 wire was cut down to 2 wire so i have to repin it now???
bump
Old Sep 14, 2004 | 10:03 PM
rev-speed's Avatar
Default Re: (h0tsihatch)
yep u have to repin it
u will need a muti-meter to find out what wire is what 4 this
actually i ll look at an obd2 car i repin tommorrow and send u the exact wires and pins to put them
Old Sep 14, 2004 | 10:42 PM
IVI's Avatar
IVI
bumper i have the same problem i checked continuity wiring voltage diffrent iacv etc etc.
Old Sep 15, 2004 | 05:03 AM
h0tsihatch's Avatar
Default Re: (IVI)
alright let me know when u find out thanx
bump
bump
bump
Modified by h0tsihatch at 4:24 PM 9/15/2004
Modified by h0tsihatch at 9:45 AM 9/18/2004
Old Sep 18, 2004 | 05:46 AM
h0tsihatch's Avatar
bump
civicb1812345
17
Aug 21, 2013 09:37 PM
rebelwolf18
Oct 8, 2009 08:56 AM
92 hatch d15b JDM
10
Feb 15, 2007 12:30 PM
ludelvr
Mar 13, 2005 05:57 PM
BlkslowCRX
Jul 5, 2003 06:43 PM
