the ground wire going to the engine
Whats it for and what happens if you dont have one. I have noticed that i was missing that ground wire from members posting their of their engines. I was wondering what it did, and if I needed to replace it asap...
The big one down by an engine mount, or the little one from the valve cover, or the cluster of wires grounded at the thermostat? They sorta share the duty of completing the ground side of any circuit to the engine. Lose the big one & the current from the starter might burn up the little one. Lose the little one & maybe get some subtle flakyness in engine control. Lose any of the ones at the t-stat & you'll lose whatever circuit it belongs to...
yea its the one going to the valve cover from the front of the Engine bay, where can I find an aftermarket ground, and I am assuming its not to expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_RS »</TD></TR><TR><TD CLASS="quote">Atleast a 30% increase in horsepower, probably 50, maybe even 75 to the wheels!!!!!!!!!!!!!!!!!!!!!!!!! :-D
j/p</TD></TR></TABLE>
WOW!!!
WOW!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1quickLS »</TD></TR><TR><TD CLASS="quote">whats the total benefit from upgrading ground wires? i have stock and they seem to do well</TD></TR></TABLE>That's the trick. They don't do any good unless your stock ones are screwed up.
j/p</TD></TR></TABLE>That's nothing... If your stock ones are altogether gone, your engine doesn't run. That's ZERO hp. Put stock ones back on, you get what, 100hp for an LS. So...
100 / 0 = INFINITE increase in power!!!!
motor motor
Jun 9, 2013 08:40 AM
