Any way to run a 3 bar sensor and a safc???
Hey eveyone. I am currently running a dsm t25 turbo with 450cc injectors and an safc. I will be putting in some crower rods and srp pistons in within a few months. I am also running an autotrajik. What I was wondering is there any way to run a 3 bar sensor so i can boost about 11psi while using an safc? Please no flaming I would just like answers.
I suppose thats possible but I have read of a few people who didnt have success with the hack at hight boost. Give it a shot though, theyre only like 40 bucks arent they? Not a big deal if it doesnt work.
I heard it won't read the voltage correctly. That is my main concern. I will be eventually converting to a 5 sp. But dropping $550 on internals and $200 for a head right after I finished my turbo kit, funds are all that easy to come by.
If money is tight go with uberdata? they have 3 bar support, and its tons better than the afc hack...I love uberdata, its simple, and works extremely well
...just a suggestion
you coudl do it with a 3bar, but you would need lots of time on the dyno to figure out which fuel multipliers work best, it is going to be a major pain, and probably wont run right because you keep adding boost but with only 7 fuel modifiers to use, it is a long shot at getting it close. Your best bet is uberdata, if you want something cheap that will let you tune up to 30ish psi effectivaly, hondata is another but option, but of coarse $$
The prob is it is very hard to run uberdata with an auto due to the conversion harness. I will eventually switch to a 5 sp. but funds aren't an option now.
i have heard u have to change the settings on the safc.. from 6in 6 out to something else'
but i am not sure what seetings, so i am not going tosay
prob someone has done it hopefully and can say
sakasaku
Oct 28, 2010 10:51 AM
NOSED_CRX_VTEC
Sep 27, 2003 05:47 AM
