Looking for easy throttle response nick nacks..
Old Sep 8, 2004 | 03:21 PM
REDTOPAlchemy's Avatar
Default Looking for easy throttle response nick nacks..
My gas pedal is feeling a bit splashy. I'd like to know if I can tighten up the slack in my throttle response. Any tips with the exception of tightening the throttle cable itself (already did that)?
Old Sep 8, 2004 | 03:23 PM
Bbasso's Avatar
Default Re: Looking for easy throttle response nick nacks.. (REDTOPChemistry)
Lube the Assembly / springs guides / and clean the air filter
Old Sep 8, 2004 | 03:26 PM
Default Re: Looking for easy throttle response nick nacks.. (Bbasso)
Got it! Uhhhh, which "assembly" are you speaking of (sorry in advance for the dumb question/response).
Opie's Avatar
Sounds silly, but what intake are you running? The reason I ask is because IMO throttle response with my AEM sucks the fat one.
Old Sep 8, 2004 | 03:28 PM
Bbasso's Avatar
the thing that holds the throttle cable on the Intake manifold, it has springs, cable guides. If I got a pic of it I'll try to post it.
Old Sep 8, 2004 | 03:29 PM
Default Re: (opie)
I have the stock intake, except no resonator assembly. Stock filter, stock TB....
Old Sep 8, 2004 | 03:31 PM
B2FiNiTY's Avatar
Yes you can easily tighten up the throttle cable. Not TOO tight though.
Old Sep 8, 2004 | 03:34 PM
Default Re: Looking for easy throttle response nick nacks.. (B2FiNiTY)
Is there any adjustment I can make to the actual pedal arm to not make is so LIMP
Old Sep 8, 2004 | 03:42 PM
B_CRUZ!'s Avatar
the adjustment nuts is on top of the intake mani. adjust it while the motor is on....
Old Sep 8, 2004 | 05:00 PM
Philly_NBP_R's Avatar
Default Re: Looking for easy throttle response nick nacks.. (b cruz.)
have you tried:
spark plugs
cap & rotor
valve adjustment
clean air filter
change oil
(why do I feel like I'm repeating myself lately?)
oh yeah, getting rid of power steering helps ALOT as well...
Old Sep 8, 2004 | 05:02 PM
johnzm's Avatar
Default Re: Looking for easy throttle response nick nacks.. (Philly_NBP_R)
itb's
lightened flywheel
Old Sep 8, 2004 | 06:05 PM
Tweakmeister's Avatar
Default Re: Looking for easy throttle response nick nacks.. (johnzm)
add medicine
boostedteg1203
Jan 14, 2010 01:17 AM
matman4444
Aug 14, 2004 04:41 PM
dust1
May 9, 2002 07:15 PM
clean
Jan 21, 2002 06:01 PM
d8168055
Nov 14, 2001 03:27 AM
