Thermo wrap?
It is worth doing. You cut down a tremendous amount of heat in the engine bay, therefore giving some extra power. Basically if you painted the manifold with some sort of corrosive paint then wrap the manifold you will not have the manifold rust out.
if this is your kit that you care about Do not do it yes unless its' made of inconel then it will crack or diminish over time. there is a bit a differince but not worth the pain. besides they become real ugly
since you are concerned with heat i think a simple heat shield works best. you can use any alumminum sheet, or i used my old cat shield, just made a braket,
and i get compliments on it
do not wrap the exhaust manifold. while it is true that is best to keep heat inside the manifold its not a good idea to wrap it because the manifold itself could overheat to the point of structural failure. personally i think it is better to wrap the ic piping.
I've seen failures. Most failures are from higher HP motors though and engines that have rather high EGT's like modded turbo rotories....321 stainless steel should be used for those application especially if there are exhuast wraps. Lightly modded 4 stroke NA motors with ceramic coated headers or 304 stainless steel (most common stainless) should be fine with header wraps. I might wrap mine just to be able to light off the catalytic converter earlier and to keep it hot during long idle periods.
Ever seen a failure?????
I didn't think so!
Another myth laid to rest.
I didn't think so!
Midwestrider
Feb 5, 2003 03:40 PM
