Thermo wrap?
Old Dec 7, 2001 | 06:16 AM
boost killz's Avatar
New User
Default Thermo wrap?
Is this worth doing to the turbo manifold or is there a greater possibility that so much heat isolation can stress the manifold eventually making it crack?
Old Dec 7, 2001 | 09:37 AM
New User
Default Re: Thermo wrap? (boost killz)
No opinions??
Old Dec 7, 2001 | 12:08 PM
FAST94GSR's Avatar
New User
its worth doing.
Old Dec 7, 2001 | 05:44 PM
boosted hybrid's Avatar
It is worth doing. You cut down a tremendous amount of heat in the engine bay, therefore giving some extra power. Basically if you painted the manifold with some sort of corrosive paint then wrap the manifold you will not have the manifold rust out.
Old Dec 7, 2001 | 06:20 PM
2000R's Avatar
Default Re: Thermo wrap? (boosted hybrid)
Does this apply to all headers or just the turbo manifold? Would a N/A or a SC car benifit from the wrap?
Old Dec 7, 2001 | 08:21 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Thermo wrap? (2000R)
Helps a little, but not really noticeable. Helps keep underhood temps WAY down.
Old Dec 7, 2001 | 08:50 PM
forcefed's Avatar
Default Re: Thermo wrap? (Mista Bone)
if this is your kit that you care about Do not do it yes unless its' made of inconel then it will crack or diminish over time. there is a bit a differince but not worth the pain. besides they become real ugly
since you are concerned with heat i think a simple heat shield works best. you can use any alumminum sheet, or i used my old cat shield, just made a braket,
and i get compliments on it
Old Dec 7, 2001 | 09:00 PM
Ben Huynh's Avatar
Wrap your downpipe, leave your manifold alone. Once downside to using Thermal wrap on street cars is the moisture that can build.
Old Dec 7, 2001 | 09:35 PM
New User
Default Re: Thermo wrap? (ben@importparts.com)
Thanks for the help guys...mucho appreciated. Latez,
Nick
Old Dec 7, 2001 | 10:41 PM
type autox's Avatar
New User
the more heat you keep in the exaust stream the more energy the exaust has, then higher velocity=lower spool up and a more responsive turbo.
Old Dec 8, 2001 | 11:07 AM
internet ay's Avatar
Default Re: Thermo wrap? (type autox)
do not wrap the exhaust manifold. while it is true that is best to keep heat inside the manifold its not a good idea to wrap it because the manifold itself could overheat to the point of structural failure. personally i think it is better to wrap the ic piping.
Old Dec 8, 2001 | 12:38 PM
paulzy's Avatar
Default Re: Thermo wrap? (internet ay)
why don't you get it coated instead?
Old Dec 8, 2001 | 06:15 PM
Zeus's Avatar
Default Re: Thermo wrap? (Slow_ass_4dr)
...coat the inside...
Old Dec 8, 2001 | 11:07 PM
Mista Bone's Avatar
D Tranny Guru
Ever seen a failure?????
I didn't think so!
Another myth laid to rest.
Old Dec 9, 2001 | 12:01 AM
yes i have seen a failure, it is not a myth.i wouldnt have said so if i didnt have a reason.
[Modified by internet ay, 9:01 AM 12/9/2001]
Old Dec 9, 2001 | 07:49 AM
CivicV10@18000rpm's Avatar
I've seen failures. Most failures are from higher HP motors though and engines that have rather high EGT's like modded turbo rotories....321 stainless steel should be used for those application especially if there are exhuast wraps. Lightly modded 4 stroke NA motors with ceramic coated headers or 304 stainless steel (most common stainless) should be fine with header wraps. I might wrap mine just to be able to light off the catalytic converter earlier and to keep it hot during long idle periods.
I didn't think so!
b20beast83
Jan 30, 2009 01:05 PM
h22 civic
Mar 14, 2008 12:13 PM
psycho_civic
Jan 16, 2004 02:12 PM
TurBoXBirD16
May 7, 2003 01:20 PM
Midwestrider
Feb 5, 2003 03:40 PM
