Vtec engagement question
Old Sep 7, 2004 | 09:59 PM
egSpoonR's Avatar
Default Vtec engagement question
ok when my Vtec engages, it doesn't feel as if it pulls that hard...almost as if it engages smoothly, no jump in rpms...different sound, but doesn't jump like my friend's, LS/Vtec...its a JDM itr motor running on a stock civic VX fuel pump (the fuel pump is what i believe the problem is)...my buddy's LS/Vtec has the USDM type-R complete head with a stock type-R fuel pump and his pulls amazing...is my problem the stock VX fuel pump? will a Type-R fuels pump cure this? thanks for all the help
Old Sep 7, 2004 | 10:23 PM
vteczone's Avatar
Default Re: Vtec engagement question (egSpoonR)
at what rpm?what ecu?any mods done?
Old Sep 7, 2004 | 10:34 PM
egSpoonR's Avatar
Default Re: Vtec engagement question (vteczone)
5200rpm, Mugen chipped P28, I/H/E, fuel rail, fuel pressure reg., ctr pistons...
Old Sep 8, 2004 | 09:35 AM
egSpoonR's Avatar
bUMp for some help
Old Sep 8, 2004 | 11:33 AM
junkyard racer's Avatar
if you are running B series (which I assume you are because of the CTR pistons) the vtec should sound different, not necessarly feel 100% different. do what I did, disconnect it (vtec sensor) and drive it around. (btw, your CEL will be on) if there is a difference, there is nothing wrong. if there is no difference, well, start troubleshooting....
Old Sep 8, 2004 | 12:12 PM
Katman's Avatar
you need tuning...
Go visit a reputable dyno place and pick up a VAFC to fine tune the Mugen program, along with some adjustable camsprockets.
btw, stock ITR VTEC x-over point is 5700rpm. Although when you go get tuned, they'll probably drop your vtec point to about 5300-5400rpm.
Old Sep 8, 2004 | 01:14 PM
egSpoonR's Avatar
Default Re: (Katman)
i have a vafc...its been tuned for vtec engagment at 5300...its tuned as much as it can be, except for the cam gears...need adjustable ones...
Old Sep 8, 2004 | 02:43 PM
Katman's Avatar
Default Re: (egSpoonR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egSpoonR &raquo;</TD></TR><TR><TD CLASS="quote">i have a vafc...its been tuned for vtec engagment at 5300...its tuned as much as it can be, except for the cam gears...need adjustable ones...</TD></TR></TABLE>
dyno tuned?
SiBuddy00
May 4, 2006 03:52 PM
JayDM_EK9
Mar 31, 2005 04:00 PM
kiddkai
Mar 24, 2005 03:18 AM
Brick Top
Oct 11, 2004 04:08 PM
1 speedstar
Apr 22, 2003 03:09 PM
