z6 oil pan...will it fit a y8 block perfect?
hmm...ok...i'll just have to rip off the z6 oil pickup from my z6 block then...thanks man...anyways...nice car...250 hp and 251 lbs. of mad torqe...****...thats crazy for 10 psi...and greddy kit too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">i dont beleive they align up, the holes are different
You are correct. They are not compatible. The hole spacing on the oil pump end as well as the radius that goes around the oil pump are different.
</TD></TR></TABLE>You are correct. They are not compatible. The hole spacing on the oil pump end as well as the radius that goes around the oil pump are different.
Gummiej
May 10, 2006 08:49 PM
