B16 cams VS 97 GSR cams... differences
Old Sep 7, 2004 | 02:05 AM
91teg's Avatar
Default B16 cams VS 97 GSR cams... differences
i have a 1st gen b16a and was wondering how much of a difference i would get if i put gsr cams in it? Thanks
Old Sep 7, 2004 | 03:23 AM
Targa250R's Avatar
be professional
Default Re: B16 cams VS 97 GSR cams... differences (91teg)
If this page is accurate, then there would be no difference whatsoever because GSR cams have the same specs as 1st-gen B16A cams.
Old Sep 7, 2004 | 03:28 AM
91teg's Avatar
so what cams should i get to make a difference. i have auto cams in the engine now. Thanks
Old Sep 7, 2004 | 03:50 AM
Idiotboy's Avatar
Planning on a turbo, or NA?
Old Sep 7, 2004 | 04:06 AM
ApexiChild's Avatar
one of my buddies did swap over from his b16a1 cams to stock GSR cams and did notice better mid range & some topend.
he has a b16 with jrsc at 8psi
Old Sep 7, 2004 | 04:08 AM
Idiotboy's Avatar
Default Re: B16 cams VS 97 GSR cams... differences (ApexiChild)
I know a guy who works at stiens with a B16 JRSC, its sweet.
Old Sep 7, 2004 | 04:44 AM
91teg's Avatar
it is an auto b16, but i am going to swap out springs/retainers/valves soon i hope. i would like to go turbo, but not until i get it in a car What valve seat pressure should i look for? i found a kit on ebay with valves,springs, and retainers for $452 made by KMS. Thanks
Old Sep 7, 2004 | 07:46 AM
GSRCRXsi's Avatar
gsr cams are slightly more aggressive then b16 cams. you wil notice some gains, but really not worth the effort.
Old Sep 7, 2004 | 08:43 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: B16 cams VS 97 GSR cams... differences (GSRCRXsi)
Considering 1st gen B16 cams are the least agressive of all B series VTEC cams, you'll notice a good difference with GSR cams, but instead you should get some CTR or 00+ ITR cams.
With my setup i'm running a CTR intake cam and a Civic Si Exhaust cam.. seems to be working pretty well.
Old Sep 7, 2004 | 11:28 AM
13sechatch's Avatar
you will get no gains from the gsr cams the durations and openings are idnetical on the first gen b16 as they are in the gsr. if you were lookin for cheap the 2nd gen b16 cams intake duration is larger. but your best bet would CTR cams or ITR
Old Sep 30, 2004 | 09:35 PM
mrnice1058's Avatar
what about b16a cams vs a 94 gsr cam is it the same?
Old Sep 30, 2004 | 09:47 PM
EL Vap133's Avatar
Default Re: B16 cams VS 97 GSR cams... differences (mrnice1058)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrnice1058 &raquo;</TD></TR><TR><TD CLASS="quote">what about b16a cams vs a 94 gsr cam is it the same?</TD></TR></TABLE>
The only stock set of cams that you will feel a difference with are ITR/CTR cams, IMO.
Old Sep 30, 2004 | 10:30 PM
Reelizmpro's Avatar
Default Re: B16 cams VS 97 GSR cams... differences (EL Vap133)
Yeah, i think these cams are perfect for a street/track B16A. If you can find them used-cheap, go for it. Otherwise, you may want to go Skunk2 or something with a little more duration/lift.
1sikhatch
Jul 10, 2006 08:25 AM
91b16civic
May 13, 2003 04:26 AM
crexer
Feb 22, 2003 01:12 AM
PYITR821
Jun 9, 2002 01:07 PM
