b18b crx.. stalls and dies...
Old Dec 6, 2001 | 05:40 PM
pg_thao's Avatar
Default b18b crx.. stalls and dies...
i swap a automatic b18b motor using a 91 usdm s1 tranny, non odb ls distributor and ecu into my crx hf, the problem is it that when i rev the car, the rpm will drop and stalls down to 200 and dies out.. i've check the timing, plug wires, and plugs, im throwing a code 7 for the tps sensor, also my idle is at 300+50.. what can i fix this
Old Dec 6, 2001 | 07:49 PM
1.8EG-T's Avatar
Default Re: b18b crx.. stalls and dies... (pg_thao)
which t-body are you using, is the tps plugged in?
Old Dec 7, 2001 | 02:38 PM
pg_thao's Avatar
im using the 95 ls tb.. and yea the tps is in, also, the car will rev up to 2 and come back down and die.. i really need help
Old Dec 8, 2001 | 02:30 PM
paulzy's Avatar
get a new tps sensor, that one might be fucked up...remember that when you replace the tps sensor, you have to recalibrate it
Old Dec 8, 2001 | 10:07 PM
pg_thao's Avatar
Default Re: b18b crx.. stalls and dies... (Slow_ass_4dr)
how would i do that? i've just gotten a new tps sensor,
ekhatch66
Aug 13, 2009 08:21 AM
Homotor
Dec 18, 2007 10:14 AM
kurinto
Jul 13, 2004 03:00 PM
H23vtecEG
Jan 28, 2003 07:20 PM
pg_thao
Dec 8, 2001 05:02 AM
