CAR IS SHAKING HELP ME..!!
Old Sep 5, 2004 | 10:47 PM
sayst's Avatar
Default CAR IS SHAKING HELP ME..!!
I have 97 Honda Accord LX. I went to trip for this weekend. My car was ok the first day. But when I came back to home, the passenger side (mostly front part) was shaking like crazy after 60mph, also the steering wheels. Do youguys have any idea on this problem?
Old Sep 5, 2004 | 11:35 PM
huyvu90's Avatar
check for bent wheels and bad axles.
Old Sep 6, 2004 | 05:01 AM
Stew Pidasso's Avatar
Default Re: (huyvu90)
Make sure your lug nuts are tight too.
Old Sep 6, 2004 | 09:15 AM
95ACEX's Avatar
Default Re: (Stew Pidasso)
how old are your rotors? If they are old/warped they could be causing the problem at high speeds. Also having your wheels balanced could fix it.
Old Sep 6, 2004 | 09:52 AM
TxTuner
Guest
Posts: n/a
Default Re: CAR IS SHAKING HELP ME..!! (sayst)
Best guess is the wheel needs to be balanced. The movement in the wheel isn't noticable at lower speeds, though it is there, and once you reach higher speeds, the wheel's "wobble" becomes more noticable due to more rotations per minute.
Old Sep 6, 2004 | 10:30 AM
Riceburner247's Avatar
Default Re: CAR IS SHAKING HELP ME..!! (TxTuner)
Yeah, Have the front end aligned and balanced. See if that's it, it usually is.
Old Sep 6, 2004 | 12:30 PM
white accord's Avatar
Default Re: CAR IS SHAKING HELP ME..!! (riceburner247)
yea i have a 97 accord also. but mine shaked between 45-60 then smoothed out a little i had it aligned and balanced. rides like a champ
Old Sep 6, 2004 | 01:35 PM
sayst's Avatar
Default Re: CAR IS SHAKING HELP ME..!! (white accord)
Thanks everyone..
I will get wheel alignment & balance probably tomorrow.
I hope the problem will be gone!
Old Sep 6, 2004 | 08:52 PM
A340600's Avatar
Yep, sounds like you need to have your tires balanced.
They will be those sticky metallic weights on your wheels. The weights in your front right may have fallen off during the trip.
I think it should cost around 30 bucks to balance all four wheels.
msinsky14
49
Jan 27, 2011 08:10 AM
RS2 FAB
Feb 1, 2008 12:11 AM
SlowSOHC-T
Oct 31, 2005 01:11 PM
RTW DC2R
Feb 6, 2004 12:21 PM
wkbmarine
Dec 5, 2003 10:37 AM
