Shakey steering wheel
Old Oct 31, 2005 | 06:08 AM
SlowSOHC-T's Avatar
Default Shakey steering wheel
Yesterday i changed my wheels due to winter coming and now my steering wheel shakes badly. It has never done this before with the old wheels...So after i switched them i went back home after noticeing the shaking, and pulled the wheels back off. The tires are in great shape and i know the wheels are not bent. So i put them back on torqued them down to spec. So i drove this morning and it started doing it again. I have recently replaced the axles, ball joints and tie rod ends. And never had this problem before...Any advice..
Old Oct 31, 2005 | 06:23 AM
98 Spec R's Avatar
Default Re: Shakey steering wheel (IWANTAHB)
It sounds like they are bent. How do you know that they are not bent?
Old Oct 31, 2005 | 06:32 AM
ghostrider dc2's Avatar
yeah....
take em out and put them back in.
are those wheels made for your car ?
oem?or what?
Old Oct 31, 2005 | 08:31 AM
SlowSOHC-T's Avatar
There not bent bc i took them to a shop and had them check em...And they said they are fine. Yes they are oem wheels, but not from a teg...
I guess i will pull them off again and try it one more time...The crazy thing is, it dosen't do it all the time. EXAMPLE: Say im driving (Cruise Control) at 65mph and it will shake, and than go away, and than shake, and than go away....WTF....any other suggestions?
Old Oct 31, 2005 | 08:45 AM
.one lane's Avatar
.likes trains
Does the car pull to one side when you drive? Maybe you need an alignment? My car whole car shakes when I drive through this section of the freeway. That's caused by my tires having uneven wear. It goes away once I pass that section.
Old Oct 31, 2005 | 09:00 AM
SlowSOHC-T's Avatar
i mean the car does need an alignment, but i've never had an issue like this from just switching wheels, and it pulls to the right a little bit. But the point is, i just switched wheels and now its shaking the **** out of my steering wheel, which makes me look like im having convoltions in my car while driving
-Andru
Old Oct 31, 2005 | 12:44 PM
BrooX's Avatar
Default Re: (IWANTAHB)
What about your brakes? When was the last time that you had a brake job done? I remember when I had a car with bad brakes and the steering wheel was very shakee due to the brakes. I replaced the drum, rotor, pads, and caliper ....no more shakee after that.
Old Oct 31, 2005 | 01:06 PM
tasco's Avatar
It can't be the brakes if he only changed the wheels. Are your wheels balanced?
Old Oct 31, 2005 | 01:11 PM
ernald711's Avatar
Default Re: Shakey steering wheel (tasco)
balance the wheels and get and alignment. shaky steering wheels are also a result worn ball joints bushings.
ribal_gh
Honda Civic (2006 - 2015)
Mar 31, 2015 10:47 PM
msinsky14
49
Jan 27, 2011 08:10 AM
H0ndas g0 Vr00m
Honda Civic (2001 - 2005)
Oct 13, 2007 02:48 PM
BLUE EH3
11
May 9, 2006 05:50 AM
JunIntegra
Sep 27, 2004 08:36 PM
