Almost new defective Thrust Bearing ??
Old Sep 5, 2004 | 02:15 PM
vteec's Avatar
Default Almost new defective Throw Out Bearing ??
Hi,
About 7k miles ago i have replaced a couple of bearings in my tranny (mainshaft ones), and as the tranny was out i decided to replace the throw out bearing with an oem one, as you ht ppl always suggested.
Today i was having really fun pushing my R, when i came to a stop and heard a whistling faint noise.
I slightly touched the clutch pedal and it stopped.
The noise is not very audible but irritating
How can a new oem t/o bearing get worn after only 7k miles?
Do you think that if i leave it like that, ie. i don't pull out the tranny and replace it, this could lead to damage to the tranny please?
Rgds,
Old Sep 5, 2004 | 02:21 PM
uNF$@#!'s Avatar
Default Re: Almost new defective Throw Out Bearing ?? (vteec)
did you grease the living hell out of it?
and.... what do you think. use a little common sense. if a faulty/failed TO bearing works as well as a regular one, why not just ditch it all together?
Old Sep 5, 2004 | 02:35 PM
vteec's Avatar
Default Re: Almost new defective Throw Out Bearing ?? (w@@t w@@t)
i mean....clutch engages ok there is only this small noise......
does it need to be replaced or not caus eof this noise...its a simple question.......
Old Sep 5, 2004 | 03:11 PM
uNF$@#!'s Avatar
right. it is a simple question, isnt it?
Old Sep 5, 2004 | 09:33 PM
vteec's Avatar
Hey,
what is your problem man???
I am just asking a question whether i should take out the tranny and replace the t/o bearing beacuse of the noise or not.
And whether if i won't, will it damage any other parts, since its still a new t/o bearing.
Old Sep 5, 2004 | 11:55 PM
Combustion Contraption's Avatar
The noise is only an annoyance and wont cause any real damage afaik.
Old Sep 6, 2004 | 12:04 AM
uNF$@#!'s Avatar
Default Re: (LsVtec92Hatch)
with this logic you could also never replace a throw out bearing.
(notice its name?)
Old Sep 6, 2004 | 02:14 AM
.RJ's Avatar
.RJ
Default Re: (w@@t w@@t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t &raquo;</TD></TR><TR><TD CLASS="quote">with this logic you could also never replace a throw out bearing.
(notice its name?)</TD></TR></TABLE>
What the **** are you talking about?
Stop being an ***.
Anyways, I would not worry about the bearing unless it gets louder - mine has been making noise on/off for the last 10k miles. If it does, pull it and relube/replace.
Old Sep 6, 2004 | 12:59 PM
vteec's Avatar
Default Re: (.RJ)
Thanks a lot guys for the help.
Infact today it didn't make the noise.....its strange..but now thanks to you i know that i don't need to pull out the tranny in the immediate future cause of it.
Once again, thank you guys....that is except w@@t w@@t who was trying to make fun of me
Rgds,
michjdm
Nov 24, 2009 02:33 PM
eg6cusco10pt
Apr 11, 2005 07:54 AM
Y2ksi
Mar 17, 2005 03:41 PM
XRacerX
Mar 10, 2004 09:14 PM
South Bay Surfer
Apr 14, 2003 08:43 PM
