Has this Ls build been done before?
Old Sep 5, 2004 | 02:06 AM
Geno's Avatar
Default Has this Ls build been done before?
Its that time, just hit 195k miles on the car and its gunna be time to rebuild soon so here is what I plan to do, I already have most of the parts. Please no posts telling me to just buy a VTEC head.
GSR crank
GSR Rods
ITR Pistons
GSR oilpump
GSR windage tray
Revhard springs, Titanium retainers
Reground cams(somewhat close to the crower short duration high lift spec cams)
P&P head
OBD1 LS ecu running a CTR fuel map with rev limit at 9.5k rpm
I was able to get most of the parts and headwork done for about $900 total. Tell me what you think or sugestions(Other than VTEC head swap as mentioned earlier)
Old Sep 5, 2004 | 07:04 AM
boosted k20's Avatar
Default Re: Has this Ls build been done before? (Geno)
i dont know if this is correct, but wont adding the GSR crank and rods in ur LS lower ur displacement? why do u wanna put all those GSR parts in ur LS
Old Sep 5, 2004 | 10:07 AM
Geno's Avatar
Default Re: Has this Ls build been done before? (boosted k20)
Yes i am gunna take a slight hit on displacement but I think the rod stroke ratio gains are worth it.
Old Sep 5, 2004 | 10:20 AM
shamoo's Avatar
Will you make something up for me please?
Not quite quite sure I understand what you're saying.
In your list of modifications, I don't see any "head" related stuff. Are you actually getting a Vtec head? Or are you just modifying your non-Vtec one? I didn't quite understand.
Anyway, I'd get a block girdle in there too while you're at it.
Old Sep 5, 2004 | 04:08 PM
Geno's Avatar
Default Re: Has this Ls build been done before? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Not quite quite sure I understand what you're saying.
Anyway, I'd get a block girdle in there too while you're at it. </TD></TR></TABLE>
Near the bottom where it says P&P head. I am going to have the head ported and polished, maybe some other stuff if i can find the $$
Old Sep 5, 2004 | 05:51 PM
shermanyang's Avatar
seems like you may end up losing a lot of power. but i'm just guessing out of my *** right now(too much to drink). hhhmmm...maybe if you had some really aggressive cams that could make up for it and be somewhat of full time vtec LS motor? damn i should shut up already...
Old Sep 5, 2004 | 07:20 PM
Geno's Avatar
Default Re: Has this Ls build been done before? (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">seems like you may end up losing a lot of power. but i'm just guessing out of my *** right now(too much to drink). hhhmmm...maybe if you had some really aggressive cams that could make up for it and be somewhat of full time vtec LS motor? damn i should shut up already... </TD></TR></TABLE>
I'll be using something close to a stage 2/3 cam, here are the specs:
Specs are Duration: 230 deg intake, 230 deg exhaust Duration @ .050" 187 deg intake, 187 deg exhaust. Gross lift w/1.75 rocker arm ratio is .444" on intake and exhaust.
Or i might just buy a set of cams if i find a good enough deal. The car will redline at 9k or higher, that all depends on where it stops making power on the dyno.
t3441813one
Dec 15, 2012 05:39 PM
blu3g
38
Jul 30, 2005 08:15 PM
master honda tech
59
Jun 12, 2005 08:42 AM
DexterThEG
Sep 30, 2003 02:44 PM
spettinger
Feb 12, 2003 03:10 PM
