R wont start. no spark?
check the under hood fuse as well the thermostat ground. It also could be an ignitor related problem. Do a search on here on how to check the the ignitor for current to see if its getting any juice.
im thinking most likely its just a burnt fuse. check all of your fuses, both in your engine bay and under the steering wheel. if that's not it, you may be unlucky and may need a new ignitor coil.
have you checked your plugs? are they soaked in fuel? if so, its probably something in the distributor like the ignitor... but yeah, check the fuses first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack »</TD></TR><TR><TD CLASS="quote">Coil or ignitor most likely. </TD></TR></TABLE>
Yup.
Yup.
LagunaSecaEG
24
Mar 7, 2007 09:14 AM
