Engine light on
Old Sep 4, 2004 | 06:48 PM
pecusio's Avatar
Default Engine light on
I have a 1998 Hx civic, I was driving in second gear and I released the clucth without pressing gas because I thought I was in neutral... obvously the car turn off after that the car didn't want to turn on... when the car finally turned on the engine light came on... I don't what to do? Do I have to take the car to the mechanich or there is something that I can do.. thanks guys..
Old Sep 4, 2004 | 06:49 PM
EX-T's Avatar
Default Re: Engine light on (pecusio)
If you have an autozone in SF, take it there b/c they will scan the code and tell you why it's on for FREE!
numbnuts22715's Avatar
You can take it to Autozone and theyll do the test thing and tell you what engine code its throwing, then look on the engine code list and find out what it is, and ask people what to do to fix it and go from there. Hope this helps.
Old Sep 4, 2004 | 07:18 PM
pecusio's Avatar
Default Re: Engine light on (numbnuts22715)
Ok guys thanks I'll do that ASAP, Do you guys thinks it is safe if I go out tonight?
Old Sep 4, 2004 | 07:22 PM
i dont see why it wouldnt be. Id do it as soon as possible if you can, just to solve the problem sooner.
Old Sep 4, 2004 | 07:23 PM
pecusio's Avatar
Yeah I already went to Autozone's website there is one really close in Oakland I'll take it there tomorrow mourning.
Old Sep 4, 2004 | 07:51 PM
donkiman's Avatar
why dont u.....
1) close the loop on your ecu
2) check what code your throwing (a long flash=10 and a short flash=1 add them up)
3) then go to the sticky in the hybrid forum for ecu codes and check what code it is. then u will know whats wrong.
Old Sep 5, 2004 | 09:48 AM
pecusio's Avatar
Default Re: Engine light on (donkiman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman &raquo;</TD></TR><TR><TD CLASS="quote">why dont u.....
what do you mean by close the loop on your ecu? I've been doing some research trying to see what I have to do to read the code on my car, but I only found stuff for cars older than 1995... what I have to do in my 1998 hx civic?
Old Sep 5, 2004 | 09:59 AM
Morning Call's Avatar
https://honda-tech.com/zerothread?id=682412
theres a reason this thread is stickied..it should be the second thread in this forum
but closing the loop he means sticking a wire in the one plug coming off from the computer...
then u turn the car on and the engine light willl blink...
blaze.1
Sep 24, 2009 11:04 AM
blaze.1
Aug 3, 2009 10:28 AM
hkhaperey
Apr 30, 2007 07:15 AM
johneejumpup
Oct 29, 2004 01:49 PM
eg686
Apr 18, 2003 01:01 PM
