need help with v-tec not working!!!!
Old Sep 4, 2004 | 10:40 AM
clos0821's Avatar
Default need help with v-tec not working!!!!
I have an LS/v-tec, 00 b16 head and 97 ls block, The v-tec is wired perfectly, I have oil in it (full), my ECU engaged v-tec in my friend's car so I know its not that. I checked all the plugs and wires, everything works. I even checked it with a test light and the ECU sends power when i reach 5800 rpm. I have no codes poping out. I clean the screen on the v-tec unit itself. I don't know what else to check.
Old Sep 4, 2004 | 12:37 PM
Nerologic's Avatar
you forgot to check one thing.... the SEARCH button..... that has been covered atleast 20 times...just search for "vtec problems" or "vtec not working"
Old Sep 4, 2004 | 12:57 PM
B16 CRX's Avatar
Default Re: (Nerologic)
I had a similar problem, it turned of to be the TPS, and I disconnected on of the O2 censors from the ECU, and now VTEC engages just fine and you might wanna check oil pressure switch as well
swizz977
10
May 25, 2011 08:15 PM
egturbo1
Aug 10, 2006 12:53 PM
clos0821
13
Sep 8, 2004 11:01 AM
vspec12
Nov 5, 2001 05:25 AM
