00 Y8 manifold on a 96 y7 head. Not sealing properly?
A friend of mine has been boosted for a few weeks now. He has a y7 longblock with a y8 manifold. For whatever reason, it is not sealing on the top portion of the head and IM. We scraped both surfaces, used a new gasket, and that didnt work. We took it off, coated it with sealant and put it back on and it didnt change a thing. Are the 96-98 and 99-00 y8 manifolds different at the flange? a local shop told me this but idk if its true, i definitly dont know enough about d series, so this is a learning experience. any help appreciated
http://www.turbochargedpower.c...1.avi
Modified by Casey at 8:26 AM 12/8/2004
aight will definitly check that out...what about the big "dish" in the IM, i dont see how it could let air leak, but its about the size of half of a grape
i was having the same problem with the IM swap. i also have a 96 dx. i tried to put the 99-00 one one there. i did seal off all the extra holes. it still had some type of vacuum leak.
so then i changed it out to a 96-98 one. it still had the same thing wrong with it. the problem was a surging idle. i checked EVERYTHING. i have been checking stuff for a week now. so i guess i am going to take it to a machine shop and see if it is warped.
all 99-00 y8 manis have extra "fuel injection" holes to save gas....you will see them cus im 100% sure thats where your leaks are coming from. seal em up and you wont have a problem. 96-98 y8s are different from the 99-00s
edit: to seal up the extra fuel injection holes on my y8 manifold....i drilled some screws into the holes w/ some gasket sealant on it to seal it up for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinCX »</TD></TR><TR><TD CLASS="quote">i was having the same problem with the IM swap. i also have a 96 dx. i tried to put the 99-00 one one there. i did seal off all the extra holes. it still had some type of vacuum leak.
so then i changed it out to a 96-98 one. it still had the same thing wrong with it. the problem was a surging idle. i checked EVERYTHING. i have been checking stuff for a week now. so i guess i am going to take it to a machine shop and see if it is warped.</TD></TR></TABLE>
your problem is most likely your pcv valve. this i am 75% sure of it....unless you got a BIG *** LEAK that makes your engine bounce from 1,000-1,500ish..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">
your problem is most likely your pcv valve. this i am 75% sure of it....unless you got a BIG *** LEAK that makes your engine bounce from 1,000-1,500ish..</TD></TR></TABLE>
i replaced it with a brand new one. cause i already thought of that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinCX »</TD></TR><TR><TD CLASS="quote">it bounces from 1.5k to 2.5k also.</TD></TR></TABLE>
i doubt your manifold has a warp in it....your best bet is to grab some carb cleaner....and just spray that **** all around your im to see wheres it leaking from. new pcv valve and still surges? thats odd indeed....better check your **** twice
how about checking it 3 times, 10 times, no wait 30 times. i have checked everything from gaskets to grouments. i can not find anything wrong. the only other thing that i can come up with is that i am using the stock dx TB. so don't have to wire up the 2 wire one.
</TD></TR></TABLE>how about checking it 3 times, 10 times, no wait 30 times. i have checked everything from gaskets to grouments. i can not find anything wrong. the only other thing that i can come up with is that i am using the stock dx TB. so don't have to wire up the 2 wire one.
freakasis
12
Mar 5, 2006 08:11 AM
Steve91
Jul 16, 2003 09:15 AM
Agent Daimon
Aug 28, 2002 05:50 PM
