Why am i still leaking oil?
Old Sep 2, 2004 | 11:44 AM
lanojp1's Avatar
Default Why am i still leaking oil?
I had my oil pan gasket changed two weeks ago because of an oil leak...well its still leaking oil from god knows where..the oil is getting onto where my header connects to my cat and is burning up causing it to smell and smoke...there are no noticable traces of oil from the engine bay view of things...where else could I be leaking from? Its really pissing me off..
Old Sep 2, 2004 | 11:48 AM
Sack Master's Avatar
Default Re: Why am i still leaking oil? (lanojp1)
Oil filter? Sending unit? Transmission?
Old Sep 2, 2004 | 11:51 AM
lanojp1's Avatar
Default Re: Why am i still leaking oil? (Sack Master)
no ******* clue...have no means of jackin the car up to take a look...look like its back to hacura...
Old Sep 2, 2004 | 12:19 PM
sPaRk'iT's Avatar
Why dont you go under the car clean all the leaking oil and follow the leaks and trace it down. You might slove your problem and double check the oil filter.
Old Sep 2, 2004 | 12:37 PM
tsdenny's Avatar
take a look at the crankshaft seal (i think) near the timming belt. look for leaks. if there is $$$$
Old Sep 2, 2004 | 03:38 PM
iwannaboostmyteg's Avatar
yeah your gonna have to jack the car up and get under there to see where is coming from because if you don't then your never going to find out. Put it up on a curb half way and lay in the gutter under it thats what I had to do to change my oil back in the day...
Old Sep 2, 2004 | 03:41 PM
lanojp1's Avatar
Default Re: Why am i still leaking oil? (iwannaboostmyteg)
i think im gunna invest in a jack or somthing...
Old Sep 2, 2004 | 04:00 PM
G-bonic's Avatar
Hijacked
maybe ur oil pan dont fit well and flat, im guessing.....
mrspeedy69
14
Feb 5, 2012 11:48 AM
TheCrimsonGhost666
Jul 8, 2009 08:21 PM
pjr710
Feb 6, 2009 10:23 AM
hondaracing1
Aug 19, 2004 05:16 PM
TurbothisLS
Feb 11, 2002 01:00 PM
