Engine on stand by... any harm?
Old Sep 2, 2004 | 08:20 AM
imaginary17's Avatar
Default Engine on stand by... any harm?
I have a 2000 B18B engine waiting to be installed on my 92 DA. I won't be installing the engine until late October. Still saving money to buy some parts. Is it bad for an engine sitting out for awhile?
Old Sep 2, 2004 | 09:05 AM
JimBlake's Avatar
Default Re: Engine on stand by... any harm? (imaginary17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imaginary17 &raquo;</TD></TR><TR><TD CLASS="quote">Is it bad for an engine sitting out for awhile?</TD></TR></TABLE>What's "OUT"?? It's not getting rained on, is it? (OK, I'm kidding about this)
Internal stuff that's exposed should probably be wiped with oil or something so they don't rust. Put a bag or something around it, but then you have to worry about water condensing inside the bag... You want to keep dirt out, but you don't want it airtight unless you can get ZERO humidity inside the bag.
Modified by JimBlake at 1:38 PM 9/2/2004
Old Sep 2, 2004 | 09:15 AM
Default Re: Engine on stand by... any harm? (JimBlake)
Thanks..
I ment the egine is out of the engine bay. Sitting in my garage doing nothing.
Old Sep 2, 2004 | 03:39 PM
iwannaboostmyteg's Avatar
cover that biznatch up and before you install it your gonna have to oil everything up but other then that it should be fine.
Old Sep 2, 2004 | 04:34 PM
Ri5e's Avatar
Default Re: Engine on stand by... any harm? (iwannaboostmyteg)
It's fine, i had a JDM b20 shipped from Japan sitting in my garage for a whole year until I finally decided to put it in. No problems, just make sure you drain the oil, put fresh new oil. Before you start the engine, pull out the spark plugs and crank the motor over a couple of times to get the bearings/cams/etc... inside lubricated.
oem_CD5
Jul 9, 2006 06:28 AM
msinsky14
Jun 8, 2006 05:50 PM
Knightmare69
Mar 24, 2006 10:54 AM
old_school_dohcvtec
Apr 6, 2005 08:54 AM
Kgb
Jul 28, 2004 09:04 PM
