ATTN: Full-RAce,LoveFAB, and similar Turbo manifold manufactures
Old Sep 1, 2004 | 08:20 PM
BEEYOND's Avatar
Default ATTN: Full-RAce,LoveFAB, and similar Turbo manifold manufactures
how do you guys run your oil return on your manifolds. they make the turbos sit extremely low where the oil drain fitting on the turbo itself is parallel to the top of the oil pan. that means the oil drain fitting on the turbo has to be a good 45degree or even a 90degree bend right??? then the oil drain hose can be ran from that fitting to the oil pan fitting..
Any problems with your manifolds making the turbos sitting so low.. eg: smoking because drain issues?? That is what concerns me!!! Let me hear your comments.
Old Sep 1, 2004 | 09:01 PM
BEEYOND's Avatar
Default Re: ATTN: Full-RAce,LoveFAB, and similar Turbo manifold manufactures (nicholashang87)
hello guys
Old Sep 1, 2004 | 09:07 PM
AFFIRMED's Avatar
I ran a 45 from the pan and the turbo my friend did the same
EM1 MIKE's Avatar
I'm using a full-race prostreet manifold, moroso oil pan and fast-turbo oil return line. I swapped the straight for another 45 degree fitting. The steel braided line needs to be cut to about 3" if not less. Once I get it finished it will look something like this:
Old Sep 1, 2004 | 10:14 PM
Full-Race Geoff's Avatar
full race manifolds do not make the turbo sit that low.
here are some pics of how the oil return should be done, using (1) 45 degree -10 AN hose end and one straight -10 AN hose end.
Old Sep 1, 2004 | 10:30 PM
BEEYOND's Avatar
Default Re: ATTN: Full-RAce,LoveFAB, and similar Turbo manifold manufactures (Full-Race Geoff)
can you repost those pixs.. or give me a link geoff..
thx a bunch guy....
Old Sep 2, 2004 | 07:59 AM
EK-Chris's Avatar
Full-Race Geoff-
Any luck on a H22 turbo kit w/ AC? I know it is still under construction...
Old Sep 2, 2004 | 08:11 AM
FOrSfEd's Avatar
Default Re: ATTN: Full-RAce,LoveFAB, and similar Turbo manifold manufactures (EK-Chris)
not to be an *** but just send him and IM so we don't get off the subject and troll on this guys thread.
Old Sep 2, 2004 | 10:29 AM
DubyaAye's Avatar
Default Re: ATTN: Full-RAce,LoveFAB, and similar Turbo manifold manufactures (FOrSfEd)
damn those re som nice *** weld.
Old Sep 2, 2004 | 10:48 AM
This One's Avatar
Default Re: ATTN: Full-RAce,LoveFAB, and similar Turbo manifold manufactures (DubyaAye)
Our Drains Are Not low by any means either, Turbo sits just about as high as say a Inline Pro Cast manfifold.
Old Sep 2, 2004 | 01:08 PM
we are not going to produce an AC compatible H series, sorry
MalcolmV8
Dec 5, 2011 05:29 PM
ashb82
Mar 22, 2010 12:50 PM
dart2.2
Jul 25, 2008 07:01 AM
RedStarGsr
Dec 25, 2003 10:21 PM
b00stedsi
Jul 28, 2002 04:17 PM
