Damn GSR overheating on me!!!!!
From: flatlandz CA 7o7 But Now In Phoenix AZ, AZ and CA, usa
Alright I have a 95 Gsr, car had a bad thermostat and it was replaced, now the car overheats at idle but when i'm moving its ok, the fan turns on only when the AC is on and i really havent heard it at idle, I cant overheat, I live in Arizona I need AC lol, plz someone help?
Modified by renegadez7o7 at 7:51 AM 9/2/2004
Fan doesn't turn on when coolant temp gets high? Hardwire your fans to a switched ignition power source, or to the battery w/ a switch for now, and replace your coolant temp sensor switch located in the thermostat housing.... I guess you should check to see if it's plugged in first lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rginter »</TD></TR><TR><TD CLASS="quote">You may need to bleed the cooling system. Check your manual for instructions.</TD></TR></TABLE>
w3rd... get all that air out
Yes try and bleed the system first. The bleeder is a 12mm fitting at the upper hose connection. Do not hardwire anything!! Find the source of the problem....
Maybe, but if the fans aren't coming in, then he needs a new coolant temp sensor switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Maybe, but if the fans aren't coming in, then he needs a new coolant temp sensor switch.</TD></TR></TABLE>Or a relay, or ???
Unplug the fan switch (in the T-stat housing) & jumper it's wires with a paper clip. Key on, that SHOULD make the fans run. If so, the relays, fuses, wiring, & motors are all good. That leaves the switch being bad. If not, post back about checking the rest of that circuit.
well yeah, but I think it's usually the switch that goes bad. My friend had to replace the one that came w/ his 99 JDM B18C-R swap, replaced it w/ a M00gen fan switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtfour43 »</TD></TR><TR><TD CLASS="quote">Yes try and bleed the system first. The bleeder is a 12mm fitting at the upper hose connection. Do not hardwire anything!! Find the source of the problem....</TD></TR></TABLE>
The 12mm on the block itself??????
