Test Pipe Throwing CEL?should i keep TP or should i get hi flo cat for a supercharger R
i have a supercharged R and CEL shuold i get a custom HI FLO CAT or leave the test pipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">i dont see why everyone is sooo worried about seeing the cel. it doesnt affect anything. </TD></TR></TABLE>
Well, when something "important" does happen, you won't know about it unless your car drives like ****.
What is the code? You should make sure it's really for the rear O2 sensor. A lot of people never got that code (myself included) even with no cat.
if you want the CEL to go away, take the o2 out of it if its in, wrap with tin foil on the sensor, put in a plastic bag to keep water out, and ziptie it to shift linkage or somewhere else. plug the o2 bung and reset your computer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey »</TD></TR><TR><TD CLASS="quote">if you want the CEL to go away, take the o2 out of it if its in, wrap with tin foil on the sensor, put in a plastic bag to keep water out, and ziptie it to shift linkage or somewhere else. plug the o2 bung and reset your computer</TD></TR></TABLE>
i've heard of this..or I'd try just doing a obd1 ecu conversion.
Ghetto Civic HX
Dec 19, 2007 10:17 AM
