Code 22 - Vtec Oil Pressure - Still engaging VTEC
Old Sep 1, 2004 | 07:56 PM
Driven's Avatar
Default Code 22 - Vtec Oil Pressure - Still engaging VTEC
got the car running.
runs strong thru the entire RPM band...
until the CEL pops on, and the fuel cut is brought down to around 6200rpms.
CEL shows a code 22.
BUT, I have a fields VTEC controller that engages VTEC regardless.
checked to see if the VTEC Oil Pressure Switch was wired correctly... yep, going to D6 (P72 ECU).
Checked to see if it was getting a good ground... yep.
Checked resistance between the switch... yep!
Checked oil level... sound as a pound.
any ideas or should i just replace it with a known working sensor and try it again...or stick with the chipped ecu idea...?
Old Sep 1, 2004 | 09:20 PM
onePOINTsix's Avatar
Default Re: Code 22 - Vtec Oil Pressure - Still engaging VTEC (Driven)
replace the sensor
Old Sep 2, 2004 | 06:24 AM
Driven's Avatar
Default Re: Code 22 - Vtec Oil Pressure - Still engaging VTEC (Sideout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">replace the sensor </TD></TR></TABLE>
damn.
I was hoping there would be a "cheaper" solution.
Old Sep 20, 2004 | 07:01 PM
92eg6's Avatar
i did all of the above and still nothing, im givin up and leavin it to a real mechanic, unless there are any other ideas, im cutting off at 6700 rpms too, i jus tried a used switch from a friends sohc and nuthin.
Old Sep 20, 2004 | 07:16 PM
TIRENECK's Avatar
Default Re: Code 22 - Vtec Oil Pressure - Still engaging VTEC (92eg6)
I get the same code too sometimes but I never had a problem reving up to 8k without cuttin out. Check the vafc, im going too, because they say that the blue wire might be lose.
Old Sep 20, 2004 | 08:45 PM
RCautoworks's Avatar
Default Re: Code 22 - Vtec Oil Pressure - Still engaging VTEC (TIRENECK)
You might want to try to clean the vtec solenoid out and see if that helps, if not I would replace the sensor with one you know that works well and see what happens.
obuhmyuh
Feb 26, 2008 10:07 AM
nelsond
Mar 29, 2007 07:28 PM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
allnapower
Apr 1, 2005 08:22 AM
danteisme
Sep 26, 2004 03:19 PM
