Close-loop weld
Old Sep 1, 2004 | 03:52 PM
prelude994e's Avatar
Default Close-loop weld
guys i need some opinions but more some advice, both are ok
i have a open dump wastegate with extended dump tube welded to get exhasut gas closer to the ground away from my block......
once fully spooled that horrible raspy noise starts, and i admit it sounds kinda nasty but i am like 70/30 toward closiing the tube and welding it back into my downpipe......
how much will this affect performance, and whats the best stragegy to complete this.....i have the DRAG kit in a 99 prelude so it is all very tight as far as space goes....
any help appreciated, but keep i mind, once welded i have to be able to get this piece in place as one unit from underneath the car avioding EVRYTHING in my way
Old Sep 1, 2004 | 06:51 PM
90DALS's Avatar
Default Re: Close-loop weld (prelude994e)
not sure if this appys to you or any honda, but my friends 95 talon had the "closed" system of the wastegate going back into the exhaust. this was stock. he went to a tubular dump tube and this decreased his creep.
he runs 17psi.
Old Sep 2, 2004 | 12:05 PM
SJcivic's Avatar
If your worried about performance loss due to the wastegate opening into the exhaust, it will be very minimal.
Rich
Old Sep 2, 2004 | 04:53 PM
Default Re: Close-loop weld (SJcivic)
haha ok well with that all said, thanks for opinions, anyone with some advice on going about this.....?
Old Sep 2, 2004 | 07:34 PM
90DALS's Avatar
looped= u hear the turbo spool.
open, you know your fast when u hear that **** dump
good= people know your a beast, bad is they know u got a turbo (if your trying to stay steath).
i think im goign to run closed loop, then just buy a 2nd o2 housing to run a dump tube on the 14b, if i want loud, then i just swap them out.
Bizzle5OH3
Sep 29, 2010 06:49 AM
Built B16A
Feb 18, 2004 12:02 PM
Duck Sauce
Jul 28, 2002 07:34 PM
rrei
Jul 18, 2002 08:06 AM
udctown
Sep 13, 2001 07:50 AM
