What is resleeving
Old Sep 1, 2004 | 12:35 PM
cbmprelude's Avatar
* B A N N E D *
Default What is resleeving
I am curious, what does it mean to have a block resleeved? How does this affect a stock engine?
Old Sep 1, 2004 | 01:04 PM
RobbieG35's Avatar
12 Years Strong
Default Re: What is resleeving (cbmprelude)
Your stock sleeves are removed, and usually stronger sleeves are put in place.
The sleeve is the circular area around your piston.
Old Sep 1, 2004 | 05:59 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: What is resleeving (HybridHatch88)
Can changeing the sleeves convert your car from open to closed deck?
Old Sep 1, 2004 | 06:18 PM
butters's Avatar
http://honda-central.com/techa...s.htm
this will go into depth about sleeving
Old Sep 1, 2004 | 08:07 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: What is resleeving (butters)
What is the space for between the outside of the sleeves and the inside of the block? How does the decreased amount of space inbetween the block and sleeves due to their increasded thickness affect the engine? Does this relate to wether a block is open or closed? Also how do sleeves attach to the block?
Old Sep 2, 2004 | 06:14 AM
cbmprelude's Avatar
* B A N N E D *
thanks for the help so far
Old Sep 2, 2004 | 05:53 PM
cbmprelude's Avatar
* B A N N E D *
Old Sep 5, 2004 | 05:46 AM
cbmprelude's Avatar
* B A N N E D *
Old Sep 5, 2004 | 11:40 AM
bpowa's Avatar
leave it up to the pros to deal with and how the sleave is attached.. there are some thing you cant diy.. just know that it is a stronger sleave.. and cost alot to do.
Old Sep 5, 2004 | 11:42 AM
JL's Avatar
JL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by butters &raquo;</TD></TR><TR><TD CLASS="quote"> http://honda-central.com/techa...s.htm
this will go into depth about sleeving</TD></TR></TABLE>
did you go read that?
Old Sep 7, 2004 | 05:10 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: What is resleeving (JL)
I read it, I'm just trying to learn
dc2_poojan
Jun 8, 2012 07:02 AM
_Endless_
Mar 11, 2004 06:37 AM
hbvetteslayer
Jun 26, 2003 08:56 PM
satan_srv
Mar 19, 2003 01:52 PM
BLKCRX
Apr 5, 2002 09:18 AM
