b16 head on GSR Block
Old Sep 1, 2004 | 04:57 AM
spcrxracer's Avatar
Default b16 head on GSR Block
Just wanted to know what was required to make this setup work.
This setup would be my "poor mans Civic Type-R"
Old Sep 1, 2004 | 07:33 AM
rioninja's Avatar
Default Re: b16 head on GSR Block (spcrxracer)
Not a whole lot. Its a pretty straightforward swap.
GSR timing belt and headbolts.
Not really a whole lot different about this setup. Pretty much use all GSR stuff
on the block, and all B16a stuff on the head. probably have to redo the coolant lines,
but its really not difficult.
Old Sep 1, 2004 | 09:07 AM
Malgerus's Avatar
Default Re: b16 head on GSR Block (rioninja)
Why would you want to -Unless you have a GSR block but no head- you'll actually lose compression, won't you? The only advantage I can see is having better IM choices.
Old Sep 1, 2004 | 10:18 AM
CRX T-Si's Avatar
Default Re: b16 head on GSR Block (Mr. S)
If your going to put another head on any block you might as well do a little Port & Polish to the head.
DIY P & P is an easy way to make some free HP, just takes a lot of patients and steady hands with the dremel.
Old Sep 4, 2004 | 02:14 AM
Malgerus's Avatar
Default Re: b16 head on GSR Block (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">If your going to put another head on any block you might as well do a little Port & Polish to the head.
If you're gonna do this, only do the exhaust ports. Leave the intake ports alone, they require more know how, and I believe the rough surface promotes the tumble effect of the incoming air.
Old Sep 4, 2004 | 03:33 AM
turboZChatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want to -Unless you have a GSR block but no head- you'll actually lose compression, won't you? The only advantage I can see is having better IM choices.</TD></TR></TABLE>
This is right the poor mans type r is actualy good with a piston rod and turbo just go allmotor gsr or b16 block gsr head
Old Sep 5, 2004 | 11:52 PM
rioninja's Avatar
I would assume that most people doing this type of thing would probably have changed the pistons to their liking anyhow.
Old Sep 6, 2004 | 12:07 AM
turbotommy's Avatar
...or milled the head and got a single layer hg
EgxHaTcHxGsR
Nov 22, 2009 10:51 PM
4g4dcruisin
10
Sep 4, 2009 09:22 AM
92b16si
Nov 30, 2006 07:33 PM
SpoonEk253
Apr 14, 2006 04:35 PM
EARLdaSQUIRREL
Apr 11, 2003 11:06 AM
