Car Hesitate while driving. Help ...............................................
Old Aug 31, 2004 | 08:11 PM
jmk2888's Avatar
Default Car Hesitate while driving. Help ...............................................
1995 Civic DX Coupe
1996 B18C-R
w/ MSD SCI (at least 5 yrs old)
SS Blaster Coil (New)
New Distributor Housing
New Ignitor
New NGK Wires
New Plugs
New MSD Cap
New Rotor
When driving past 4000 RPM the car hesitates and does not Rev smoothly to Redline.
When I past 4000 RPM the tach gets slightly jumpy.
What could it be?
I have check the fuel filter & fuel pressure, they are o.k.
Everyone tells me it's the Ignition, but I have changed almost everything.
How can you tell if MSD is going BAD?
I'm going to take out the MSD on Saturday and go back to stock.
Hope it works out.
Anyone else have any ideas??
Old Aug 31, 2004 | 11:15 PM
b19coupe's Avatar
Default Re: Car Hesitate while driving. Help ............................................... (jmk2888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmk2888 &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to take out the MSD on Saturday and go back to stock.</TD></TR></TABLE>
That's the first thing I would try.
Old Sep 1, 2004 | 06:42 AM
jmk2888's Avatar
Default Re: Car Hesitate while driving. Help ............................................... (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
That's the first thing I would try.</TD></TR></TABLE>
How do you if MSD Box is going Bad?
DSR!'s Avatar
it could be the tps sensor
Old Sep 1, 2004 | 12:38 PM
jmk2888's Avatar
Default Re: Car Hesitate while driving. Help ............................................... (DSR!)
It's on top of the Throttle body?
Old Sep 1, 2004 | 02:44 PM
b19coupe's Avatar
MAP sensor is on top of the throttle body. TPS is on the side opposite the throttle cable.
Old Sep 1, 2004 | 05:40 PM
velocitytrends's Avatar
Check all your grounds while your at it too! Grounds are very important!
Old Sep 1, 2004 | 07:20 PM
jmk2888's Avatar
Default Re: (velocitytrends)
All grounds are checked.
How do I know or what kind of signs of bad TPS sensor or IACV?
No Cel's.
So it's mechanical right?
Modified by jmk2888 at 5:26 AM 9/2/2004
Old Sep 1, 2004 | 09:31 PM
Combustion Contraption's Avatar
Measure the resistance between two of the TPS wires, i cant remember the colors off the top of my head, i wanna say red and white/green and make sure theres 0.045v at closed throttle
Old Sep 2, 2004 | 10:02 AM
jmk2888's Avatar
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Measure the resistance between two of the TPS wires, i cant remember the colors off the top of my head, i wanna say red and white/green and make sure theres 0.045v at closed throttle</TD></TR></TABLE>
TPS is fine. Thanks
Any other Ideas?
Old Sep 2, 2004 | 05:11 PM
jmk2888's Avatar
Default Re: (jmk2888)
Does MSD kill ignitors (ICM) ?
I have just changed my ignitor and everything was fine for a 1 or 2 days.
Then same problem afterwards.
How long does a ignitor last?
I hope I do not need to replace it again, it's cost me $170.00
Old Sep 2, 2004 | 09:21 PM
jmk2888's Avatar
ttt
Old Sep 4, 2004 | 03:38 PM
jmk2888's Avatar
I took out the MSD system today and went back to stock.
Works like a charm, the car never ran better.
on MSD products, especially the SCI box.
I'm going call MSD on Tuesday and have them repair it for free.
Hopefully after I get it back, I sell it on ebay or something.
I'll never trust MSD ever again.
Thanks to all the guys that tried to help me.
Old Sep 4, 2004 | 08:40 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmk2888 &raquo;</TD></TR><TR><TD CLASS="quote">I took out the MSD system today and went back to stock.
Works like a charm, the car never ran better.</TD></TR></TABLE>
Told you !
There is a thread like this at least once a month.
MSD
OEM
Old Sep 4, 2004 | 11:06 PM
jmk2888's Avatar
Default Re: (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Told you !
MSD
OEM </TD></TR></TABLE>
Sorry, I had to learn my lesson the hard way.
Old Sep 5, 2004 | 05:19 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmk2888 &raquo;</TD></TR><TR><TD CLASS="quote">I had to learn my lesson the hard way.</TD></TR></TABLE>
You are not alone there. I run into the brick wall quite often myself. Hopefully we get smarter as we get older.
torr
Apr 24, 2024 09:35 AM
LSTEG96
Oct 14, 2007 11:25 PM
jmk2888
Sep 4, 2004 03:38 PM
FastAllmotorLsVtec
Apr 16, 2004 11:12 PM
4inspeed
Feb 9, 2004 01:13 AM
