Shift Linkage *roll pin*
ahh, im ready to pull my old junk out of my 90 civic hatch. But before i can i need to take off the torque rod and linkage. Well theres a roll pin in the shift linkage...that seems to be impossible to get out. In the book it shows the guy just grabbing it out with his fingers YEAH RIGHT
Does anyone know how to get this out? would be most appreciated
You need the correct sized punch and a good hammer. Make ABSOLUTELY SURE THAT THE PUNCH IS THE RIGHT SIZE. Did you catch that? If the punch is too small then it will get stuck inside the pin if its to big then the punch will get stuck inside the linkage. Don't ask me what size it is cause its the one one with the nasty hammer marks in MY tool box.
sometimes its just easier to unbolt the shifter from inside the car and yank out the shift linkage with the motor. if you need to reuse the shift linkage it is a lot easier to get out when its out of the car then while you are under it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ]{iwi »</TD></TR><TR><TD CLASS="quote">do u guys reuse the pins or what? if not what do u use when puting it back together just wondering</TD></TR></TABLE>
i always reuse, works fine.
Or go to honda and buy one for $ 1.50
http://www.geocities.com/senpa....html
go to sears, and buy assortment of metric punches. You will need them again someday anyways.
wow this topic has been covered before. next time search bro but good job helping him out guys.
to all of you who served Honda-tech proudly.
i take that bitch pin out in 5 seconds
take a med size phillips screwdriver, a tube and a hammmer
place the screwdriver on top of the pin, and rest against the tranny.... so u can reach and hammer it, use the tube and place it on top of the screwdriver so u are able ot hit it and push the screwdriver..
just give it a good wack
always works for me and its out in 5 seconds
i use 10mm body bolt and a 3" extension with a 10mm socket on it. hit it a couple times and it will flatten the end couple threads, unscrew the bolt from the pin, and you have a punch. whack it a few times with a hammer and it should pop out.
also, if you can get to it, a couple 6" extensions work very well to pound it out from the top..
ALLMOTOR CRX
11
Mar 29, 2007 07:34 AM
sleeper_gsr
Sep 7, 2005 06:16 AM
rasinhell
Jan 14, 2005 06:25 PM
