radiator leak, tiny hole on tube... is it fixable with jb weld?
Old Aug 31, 2004 | 04:30 PM
ID_ten_T's Avatar
Default radiator leak, tiny hole on tube... is it fixable with jb weld?
okay, working on the car today, i accidentally dropped a wrench in my engine bay and it punched a tiny hole on one of the radiator tubes. i know anyways, the hole is tiny, about the size of a ballpoint pen tip, but it is big enough that coolant started to leak out. anyways, is this fixable with jb weld? if not, what do you suggest? i really dont want to get a new radiator at this time. please help, thanks in advance.
*cliff notes*
- tiny hole on radiator tube
- leaks coolant
- can i fix it with jb weld?
- if not, what can i do?
Old Aug 31, 2004 | 04:34 PM
boost fed ls's Avatar
Default Re: radiator leak, tiny hole on tube... is it fixable with jb weld? (ID_ten_T)
I would just replace it. It will save you a HEAD ACHE in the long run
Old Aug 31, 2004 | 04:48 PM
Casey's Avatar
Default Re: radiator leak, tiny hole on tube... is it fixable with jb weld? (boost fed ls)
try a pouring a can of black pepper while the car is running into the radiator. either that or a hard boiled egg thats had the shell peeled off...seriously. but just buy a new radiator if you want it done 100% right
Old Aug 31, 2004 | 06:19 PM
22psicrx's Avatar
Default Re: radiator leak, tiny hole on tube... is it fixable with jb weld? (Casey)
Old Aug 31, 2004 | 06:24 PM
donkiman's Avatar
sheeeeit i jb welded my cracked pistons and broken rods back together. works like new
(jk)
Old Aug 31, 2004 | 06:26 PM
sci motorsports's Avatar
blocksealer is your friend
Old Aug 31, 2004 | 07:41 PM
ID_ten_T's Avatar
Default Re: (sci motorsports)
what about bars liquid aluminum? also, is block sealer compatible with coolant/antifreeze?
Old Aug 31, 2004 | 07:53 PM
green91's Avatar
i used that 3m window weld on a plastic part of my radiator as a temporary fix and it held.. ghetto idea though
Old Aug 31, 2004 | 08:49 PM
Sinner's Avatar
I knocked a whole in my AC condencer.. pretty much the same thing. I got some alumium welder. I havent had a problem since. btw it was a pretty big hole.
Old Aug 31, 2004 | 09:19 PM
FormulaGSR's Avatar
Default Re: (Sinner)
What cant you fix with jb weld
Old Aug 31, 2004 | 09:49 PM
sporkcrx's Avatar
Default Re: (FormulaGSR)
I've had two leaks on two radiators, one in the fin part, and one on a tank. I fixed both perfectly with some clay crap from your common auto parts store. The clay that I have is green, you just mix it with a gray clay, put it on the leak, and it dries rock hard. Been like that for 3+ years.
Old Aug 31, 2004 | 10:14 PM
ID_ten_T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">try a pouring a can of black pepper while the car is running into the radiator. either that or a hard boiled egg thats had the shell peeled off...seriously. but just buy a new radiator if you want it done 100% right</TD></TR></TABLE>
what effects will black pepper or eggs have on your water pump?
Old Aug 31, 2004 | 10:45 PM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ID_ten_T &raquo;</TD></TR><TR><TD CLASS="quote">
what effects will black pepper or eggs have on your water pump?</TD></TR></TABLE>
Yea, stay away from the grandpa farmer solutions
Old Aug 31, 2004 | 11:09 PM
Casey's Avatar
not any worse than that **** they sell at the store taht you put in your coolant to fix a leak
Old Aug 31, 2004 | 11:18 PM
honda9369's Avatar
lmfao
Old Sep 1, 2004 | 03:52 AM
Casey's Avatar
Default Re: radiator leak, tiny hole on tube... is it fixable with jb weld? (honda9369)
im not joking...i learned this from an ASE master mechanic in my heating and cooling class. i didnt believe him either untill a friend tried it
Old Sep 1, 2004 | 07:25 AM
earl's Avatar
JB weld will just crank on you. That clay stuff actually worked, however.
Old Sep 1, 2004 | 07:35 AM
Mase's Avatar
i fixed a radiator w/ jb weld. **** worked fine.
Old Sep 1, 2004 | 07:36 AM
DIRep972's Avatar
Smarter than you
Default Re: radiator leak, tiny hole on tube... is it fixable with jb weld? (Mase)
Just switch to Meth, then you won't need the radiator.
Old Sep 1, 2004 | 07:43 AM
Mase's Avatar
Default Re: radiator leak, tiny hole on tube... is it fixable with jb weld? (DIRep972)
better yet, just shoot nitrous through the coolant lines, it would be sweeto...
Old Sep 1, 2004 | 07:48 AM
DIRep972's Avatar
Smarter than you
Dude, just get a Motec. The base map alone will fix your coolant leak.
Old Sep 1, 2004 | 07:57 AM
Mase's Avatar
true, i hear they also make you a killer omelet and a nice batch of columbian coffee each morning for breakfast
Old Sep 1, 2004 | 08:02 AM
DIRep972's Avatar
Smarter than you
No you are confused.. That is Hotec. btw, tell your mom thanks for the coffee and omelet she made me for breakfest.
Old Sep 1, 2004 | 08:13 AM
mos's Avatar
mos
My friend has a GSR which started to leak. He put some stop leak in, I think it was prestone or valvoline or something, and his radiator exploded. I mean not in a firey ball or anything. But it burst.
There are epoxies around that can easily withstand the temperature of a radiator repair. Depending on how large the repair is, they may not be able to withstand the pressure however. If its just a small hole, I'd think the jb or devcon would work fine. But because of the previous posts about the clay working better, now I think I'd try that first! Anybody got a URL for that clay stuff?
dwn2earth922
Sep 12, 2009 10:00 AM
tommyt761
Oct 12, 2006 01:00 PM
eastsideATX
Jul 6, 2005 02:56 PM
BluLuder
Jul 29, 2002 11:29 AM
EGh22aEG
Jan 9, 2002 06:37 PM
