Crx W/gsr 1/4 mile stock
Old Aug 31, 2004 | 03:55 PM
tRex99's Avatar
Default Crx W/gsr 1/4 mile stock
Well im still in the dicision of the gsr vs lsvtec...I want to do the lsvtec but i cant have a motor go on me since this is my only car as of well for awhile..long while..I beleive im going to go with the gsr...my question is i know my car can run 14.8 consitently so im guessing an SiR(B16) rex runs around about 14.2?? Ive heard the ls vtecs run from 13.5-14.2 but it leaves me thinking well would a gsr run the same 1/4 as an ls vtec or would it be off by like .2 ? OH another ? i love the sound of Vtec from the B16 because its a single stage and wicked sound but i dont really hear that with gsr's why is that? it sounds just smoother and a queiter vtec???
Old Aug 31, 2004 | 04:00 PM
out_of_order's Avatar
ls,vtec with a b16 head is better from what i heard its a "mini type-r"
Old Aug 31, 2004 | 04:12 PM
StupidSlowRSX's Avatar
Default Re: (gotriceboy05)
b16 head the best flowing head of the b series... Thats why the head from the b16 is used on ls vtec setups and not a GSR head
average time for a b16 crx is 14.7... 14.5 wit a good driver and on a cool day
Old Aug 31, 2004 | 04:17 PM
tRex99's Avatar
Yea i figured it was a little better cause i guess the block is actually a tiny bit bigger with the ls...im not sure if this is dumb but has anyone ever put a b16 head on a gsr??? My whole problem is the OBD thing...i can get an sir head and be odb0 but then i come into visual problems with smog because vaccum lines...i can get a gsr but then its obd1 or 2..i would be guessing on a 94-95 gsr cause its obd1 so its probably just easier to convert.
Old Aug 31, 2004 | 04:20 PM
HamiltonRex's Avatar
Default Re: (StupidSlowCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX &raquo;</TD></TR><TR><TD CLASS="quote">b16 head the best flowing head of the b series... </TD></TR></TABLE>
I beg the differ.
So the factory port job on the ITR dosent increase its ability to flow better?
FYI: Somewhere i seen a chart, a GSR and B16 cylinder head where put on a flowbench and the B16 outflowed it by like 5% up top, down below they were dead even.
LsVtec will stay together all day long if you build them right, and you can build one right for cheaper then a gsr swap. Plus they make more power and more TQ.
Old Aug 31, 2004 | 05:10 PM
Default Re: (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">
I beg the differ.
LsVtec will stay together all day long if you build them right, and you can build one right for cheaper then a gsr swap. Plus they make more power and more TQ.</TD></TR></TABLE>
ya and c1 and c5 heads are soooo expensive
Old Aug 31, 2004 | 05:14 PM
kshymkiw83's Avatar
I beg the differ.
the only diffrence between a C5 head and a B16 head is the P&P. Same head besides that.
Old Aug 31, 2004 | 05:52 PM
tRex99's Avatar
Default Re: (kshymkiw83)
Damn you guys are making my mind crazy!! Ok damnit its final....im doing lsvtec...i have an ls motor in my rex BUT im going to buy another one so i can work on putting it all together then sell my motor stuff i have as a swap for around 1000 so i can buy either a b16 or gsr tranny and my ecu...setup below
B18(A/B) Block
B16 Si-R DOHC Vtec head
B16 Pistons
ARP rod bolts
ARP head studs
ARP crank main bolts
Vtec oil pump (B16)
Vtec water pump(B16)
B16 Timing belt
B16/GsR tranny
Crank Pulley
Flywheel (ITR 14lbs or Chromoly 11-12lbs)
Clutch
Sounds about right? i put the pulley clutch and flywheel just cause its my list of stuff i need and want. Also now the axles are suppose to be ls axles even with b16 tranny but what about the intermediate shaft??? Ls or Vtec????
Modified by tRex99 at 7:28 PM 8/31/2004
Old Sep 1, 2004 | 02:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kshymkiw83 &raquo;</TD></TR><TR><TD CLASS="quote">
the only diffrence between a C5 head and a B16 head is the P&P. Same head besides that.</TD></TR></TABLE>
No.
C5 head, has different cams, and better valvetrain.
The only difference in the casting is a factory PORT not <U>polish.</U>
Your setup sounds good. Remember to replace all gaskets and bearings.
Old Sep 1, 2004 | 02:48 PM
Default Re: (tRex99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRex99 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by tRex99 at 7:28 PM 8/31/2004</TD></TR></TABLE>
You will also need a lsvtec oil line kit.
Axles use 90-91 LS axles, along with intermediate shaft. You can use any b series intermediate shaft. Just make sure to get the proper seal for the 90-91LS (or whatever transmission is used) rule of thumb. Match the seal to the transmission.
Good luck!
Old Sep 1, 2004 | 04:34 PM
Malgerus's Avatar
Default Re: (Manuel)
B18C in a CRX would run easy 13's up here.
14.3@97 with basically stock B16A. My vote goes to LS/VTEC with B16A head
Old Sep 1, 2004 | 10:39 PM
686_ef's Avatar
ls/vteck is the way to go for the tQ. gsr has a whole lot of rms and they go up fast but they die out at top. and in our shoe boxes tQ is what you need so the car can strech to the finish line. MY VOTE IS LS/VTECK.13.89 ON NITTO 555R, GSR HEAD LS STOCK BOTTOM END! OH YA FULL INTERIRER.
Old Sep 2, 2004 | 10:06 AM
spcrxracer's Avatar
Default Re: Crx W/gsr 1/4 mile stock (tRex99)
why not just build b18 vtec block with b16 head
also.... Which head do yall prefer for B20? GSR or B16?
Old Sep 2, 2004 | 03:02 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Crx W/gsr 1/4 mile stock (spcrxracer)
I've asked that question to 3 engine builders (locally), and the consensus is the GSR head is the best.
Old Sep 2, 2004 | 05:20 PM
StorminMatt's Avatar
Default Re: Crx W/gsr 1/4 mile stock (mar778c)
ET depends on alot of other stuff besides power, like traction and a driver's ability to launch well. For this reason, it is hard to estimate ET. But trap speed should be 96-98MPH.
Old Sep 2, 2004 | 05:54 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Crx W/gsr 1/4 mile stock (StorminMatt)
Just to give you an idea.
My B18C5 with 182 HP at the wheels does 105 MPH at the track.
Fast enough for high 12's but I run a consistent 13.4
Old Sep 2, 2004 | 06:39 PM
japrex's Avatar
Default Re: Crx W/gsr 1/4 mile stock (The new Spaceballs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The new Spaceballs &raquo;</TD></TR><TR><TD CLASS="quote">Just to give you an idea.
damn
Old Sep 2, 2004 | 08:11 PM
bseriesboosted's Avatar
Default Re: Crx W/gsr 1/4 mile stock (japrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japrex &raquo;</TD></TR><TR><TD CLASS="quote">
damn </TD></TR></TABLE>
i was thinking the same thing.... I wants me a c5
Old Sep 3, 2004 | 04:31 AM
No Big Whoop
Default Re: Crx W/gsr 1/4 mile stock (bseriesboosted)
I've wanting to sell my complete swap.
I let this post get buried.
https://honda-tech.com/zerothread?id=865934
hatchvtec
13
Jun 18, 2006 11:48 AM
SEXY TIME!
11
Mar 22, 2006 08:44 AM
MxJones92
10
Feb 1, 2006 10:12 AM
EkPudge
Oct 25, 2005 02:28 PM
686_ef
Mar 3, 2005 05:03 PM
