LS VTEC B16 or GSR Head
Obviously the GSR head is a better head, but if you were building an LS VTEC on a budget if you could get a b16 Head for 500 or a gsr for 900 which one would be a better route.
Re: LS VTEC B16 or GSR Head (void_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by void_accord »</TD></TR><TR><TD CLASS="quote">gsr got two stage vtec
not sure what the b16 has</TD></TR></TABLE>
b16 has 3 stage so you really hit vtec 3 times in every gear
1 Post
Obviously it all depends on what you are trying to do as well man, a GSR head will have higher compression than a B16/B18C5 head but it will not flow as well. At max lift, a B16 head and a B18C5 head flow within a couple of cfm of each other as they are cast from the same mold. The only differences between the two from the factory is a MILD port job on the R head and dual valve springs.
In my opinion, the B16 is a better option and the GSR for both price and maximum power output.
ProjectEF9SI
02-17-2007 04:20 PM
hatchvtec
13
06-18-2006 11:48 AM
686_ef
03-03-2005 05:03 PM
