shifter/tranny problem
Old Aug 31, 2004 | 01:52 PM
jerbear!'s Avatar
Default shifter/tranny problem
i dont know exactly what the problem is but after i swapped a tranny there is excessive (a **** load) movement in the shifter and seems like the whole motor is moving when on the throttle. what could it be? im guessing its the mount on the firewall but i dont know.
Old Aug 31, 2004 | 01:57 PM
2fast4u831's Avatar
I'm really 2slow
im guessing that too.
Old Aug 31, 2004 | 02:14 PM
Street Ghost's Avatar
Default Re: shifter/tranny problem (jerbear!)
Movement in the shifter can mean bad shifter bushings or the shift stick is connected to the shifter rod very loosely.
For the motor shaking under throttle.. probably worn out motor mounts.
What tranny did you put in?
Old Aug 31, 2004 | 02:24 PM
jok's Avatar
jok
Default Re: shifter/tranny problem (JDM Ninja)
I would re-confirm to check the mounts and the bushing(s), I'll check my book on it for yah a little later tonight. What car do you have(Make/Model/Tranny? etc.???) would help in my search. Are there any sounds? Do you drive pretty hard?
Old Aug 31, 2004 | 06:50 PM
jerbear!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Ninja &raquo;</TD></TR><TR><TD CLASS="quote">Movement in the shifter can mean bad shifter bushings or the shift stick is connected to the shifter rod very loosely.
What tranny did you put in?</TD></TR></TABLE>
a cx pos.
Old Aug 31, 2004 | 08:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! &raquo;</TD></TR><TR><TD CLASS="quote">
a cx pos.</TD></TR></TABLE>
Probably the shift rod inside the tranny is wearing down since it's made of aluminum. My shifter has some play in it also while it's in gear and I replaced the bushings and checked everything for loose connections. I even put in that 'bitch pin' that connects the shifter rod to the tranny. And yet, I still have a little slope in the shifter. So I had someone move the shifter while it was in gear and I observed what was going on from under that car and it seemed like the free play was coming from inside the tranny. So my guess would be the shift rod in the tranny is wearing out.
9818tegr
May 5, 2022 06:49 AM
skateoholic
Feb 22, 2009 05:30 PM
hondazccivic
Aug 10, 2008 10:48 AM
Spade
35
May 11, 2004 01:07 PM
