is it true...
Old Aug 31, 2004 | 10:40 AM
teg969's Avatar
Default is it true...
that removing the mid part of the exhaust on a 97-01 lude is the worst thing to do....
like removing cat will make you lose power? can someone confirm to me if this is true or not? thanks
Old Aug 31, 2004 | 10:44 AM
bb6h22's Avatar
Default Re: is it true... (teg969)
it wont lose HP, but the gains from it isnt worth the troubles it brings up. try a search
Old Aug 31, 2004 | 10:48 AM
bb6h22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg969 &raquo;</TD></TR><TR><TD CLASS="quote">that removing the mid part of the exhaust on a 97-01 lude is the worst thing to do....
like removing cat will make you lose power? can someone confirm to me if this is true or not? thanks</TD></TR></TABLE>
Gutting a cat is a bad idea.
Old Aug 31, 2004 | 10:59 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: is it true... (bb6h22a)
Good luck on passing emissions w/ a gutted cat. Just go buy a HI-FLOW cat.
Old Aug 31, 2004 | 11:02 AM
teg969's Avatar
Default Re: is it true... (Sticky Tires)
will a high flow cat make a good difference? or is it the same as jsut rmoving it? thanks
Old Aug 31, 2004 | 12:26 PM
SlammedAccord96's Avatar
It will make a slight difference (not as much as a test pipe or gutted cat) but IMO it's not worth it - sometimes you can't even pass emissions with a high-flo, I guess it depends on how strict emissions testing is in your area.
Old Aug 31, 2004 | 12:33 PM
Slipknt777's Avatar
Default Re: is it true... (SpeedFreak03)
i would think back pressure would be a factor.
Old Aug 31, 2004 | 12:37 PM
revlimitx04's Avatar
Default Re: is it true... (Slipknt777)
backpressure is a big thing with our engines, The only time you want a diffrent cat setup is when your forced induction.
Old Aug 31, 2004 | 02:03 PM
charliec's Avatar
Default Re: is it true... (revlimitx04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revlimitx04 &raquo;</TD></TR><TR><TD CLASS="quote">backpressure is a big thing with our engines, The only time you want a diffrent cat setup is when your forced induction. </TD></TR></TABLE>
huh? i was under the impression that backpressure was bad.
Old Aug 31, 2004 | 02:15 PM
98TypeSH's Avatar
Default Re: is it true... (charliec)
So far its all been hearsay.
Id say, some back pressure is good. If any of you have worked on a goped or anything like that, if you mess with the exhaust it will change the back pressure, and slow you down BIG TIME. thats a 2stroke though so....
Im not really 100% sure as i am not a liscensed rocket scientist.
Old Aug 31, 2004 | 05:24 PM
PirateMcFred's Avatar
Put up or shutup. Please quantify your statement. SHOW me that back pressure is a good thing for any prelude engine. 'Cause I have dynos that PROVE otherwise. My Lude makes 5 more torque and 3 more horsepower open header vs. crush bent 2.25" exhaust. Tell me why that is. Hmmm? If you have nothing to contribute don't spread misinformation. But then again please prove me wrong I would love the information.
Pirate
EDIT:
red is open header
blue is crush bent 2.25"
As anyone can see gains across the board.
Modified by PirateMcFred at 10:29 AM 9/1/2004
Old Aug 31, 2004 | 06:04 PM
2lude4u's Avatar
Default Re: is it true... (PirateMcFred)
From what I understand a little backpressure helps with low end torque, but does inhibit mid and high range power. I'd like to compare those dyno numbers and see if it agrees with what I've heard or not.
faxshatch
25
Apr 1, 2008 04:52 AM
Boring
Jan 1, 2005 04:31 PM
HT Chaplain
Sep 19, 2004 03:34 AM
b16_madman
28
Sep 26, 2003 08:00 PM
UA6 BALLER STATUS
Aug 20, 2003 11:23 PM
