Converting wraparound harnesses to a bolt in temporarily?
You guys have any creative ideas?
I don't have a rollbar in yet, but I'd like to have a harness to supplement my Sparco.
Damn you *****. There's plenty of autocrossers who use harnesses w/o a rollbar...
Anyone else want to be more mature?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthx32 »</TD></TR><TR><TD CLASS="quote">You guys have any creative ideas?
I don't have a rollbar in yet, but I'd like to have a harness to supplement my Sparco.</TD></TR></TABLE>
I don't see how a set of wrap-around shoulder straps is going to be long enough to mount anywhere safe other than a horizontal bar behind the seat. They're just too short to reach anything else unless you're in a del sol or mr2 or something like that.
BTW, there's nothing "immature" about someone looking out for your safety.
I don't have a rollbar in yet, but I'd like to have a harness to supplement my Sparco.</TD></TR></TABLE>I don't see how a set of wrap-around shoulder straps is going to be long enough to mount anywhere safe other than a horizontal bar behind the seat. They're just too short to reach anything else unless you're in a del sol or mr2 or something like that.
I was able to use my G-force harness with a C-pillar bar that I got from stable energies. However, before I got the C-pillar bar, I ran the following setup:
I bought two of these:
I ran the harness straps into them.
Then I mounted an eye bolt into the rear upper seat bolt attachment point.
I attached both harnesses to this eye bolt.
This allowed me to use the rear seat belts when necessary and the harness during autox's.
Disclaimer: remember, the purpose of this setup is mainly to hold me in the seat tight during autox. I do not recommend this setup for track events. Even for autox it can be deemed "dangerous" w/o a roll bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc »</TD></TR><TR><TD CLASS="quote"> I do not recommend this setup for track events. Even for autox it can be deemed "dangerous" w/o a roll bar. </TD></TR></TABLE>
A C-pillar bars strong enough for this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout »</TD></TR><TR><TD CLASS="quote">
A C-pillar bars strong enough for this?</TD></TR></TABLE>
The C-pillar bar or single eyebolt setups aren't for safety at all. They're just to hold you in the seat better during autox. I had a similar setup in my Si when I was autoxing, with eyebolts and snap-on connectors for both seat and shoulder harness. Only hooked them up at events, and used the stock belts otherwise.
I don't recommend any type of harness without a roll bar. Been discuss heavily in this forum... but anyway. The C-Pillar bar is strong enough for me to create the needed tension in the belts to hold me tight, but it is not in any way roll over protection.
Thanks David.
The wraparound straps were long enough to reach? I guess it was an Integra, so it shouldn't have been too far anyways.
Yes, they were long enough. But, I am not sure all harnesses are made the same length. If you already have a harness, just do a test fit or if you are purchasing new ones, the G-force 5-point worked well for me.
Although it depends on course design, I have seen pictures of people that rolled during an autoX event. It was probably more due to the course design , but still there is that chance.
A roll bar is only 350 new from autopower and can be installed in about three hours or so.
I don't see why anybody would be willing to risk their life for 350 dollars. Doesn't really make all that much sense. You probably paid more than 350 for your strut bars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr »</TD></TR><TR><TD CLASS="quote">Although it depends on course design, I have seen pictures of people that rolled during an autoX event. It was probably more due to the course design , but still there is that chance.</TD></TR></TABLE>
But speeds are usually less than 60 mph... for which the car was originally designed to handle. The problem with rollover REALLY starts to play a role when you upping the speed to well beyond highway speeds, something the original designers of the chassis never intended.
Not saying that the car (and/or your head) will always survive a 60 mph rollover but the car, at least, affords a reasonable factor of safety.
Andy - who has a rollbar and a harness in his autox car.
SpoolinEK9
Jun 21, 2007 12:44 PM
Btothe3rdDegree
19
May 4, 2004 11:43 AM
