Installing takata harnneses to my roll cage??
Location: Seattle/Ligonier, WA/PA, United States of Honda
How do i setup the shoulder belts to wrap around the cage and get rid of the i bolt clip? yes dont hassle me about the 5th point i have one..
memoryFAB.com representative
Re: Installing takata harnneses to my roll cage?? (SpoolinEK9)
see i ran into this issue, i just have them in the stock rear seat belt area w/ eye bolt.. the typical spot. the reason i didnt use my harness car is cause the clips are sown in and you'd have to rip them out.. from my understanding unless im completely off base here..
Your belts have clip-in style ends on the shoulder belts?
Normally belts just have them on the lap belts.
OG triple OG
Re: Installing takata harnneses to my roll cage?? (rotten)
i have the 340mph which is the long verstion , i bought crow 3 bar slides and wrapped them around my harness bar.
Re: Installing takata harnneses to my roll cage?? (ATS*Mark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATS*Mark »</TD></TR><TR><TD CLASS="quote">i have the 340mph which is the long verstion , i bought crow 3 bar slides and wrapped them around my harness bar.
the right way to do it
did you have to remove the stitches that hold the buckle in? i have the 340 as well and would like to use my harness bar for what its intended! thanxx
OG triple OG
Re: Installing takata harnneses to my roll cage?? (spock_rocker)
yo dont have to undo any stiching or cut anything. theres a little bar with a spring on the adjustment clasp that u take off and the eye hook comes right off.
#1 Super Guy
Don't the different length harnesses have different amounts of stretch designed into the belt fabric. The long belts that are meant to connect in the rear seat-belt mounts have much less stretch per unit of fabric than the short "roll-bar" mounted belts. This is so that once mounted, both types of belts react the same in a collision.
IE: Longer belt w/ less stretch reacts the same in a crash as a short belt w/ more stretch.
I have been told that this is why you should NOT modify the mounting position of the belts. If you use a long belt wrapped around a harness bar, there won't be enough stretch during a collision and can cause injury...
Either way, you may want to contact the harness manufacturer about this (it's always a good idea when modifying safety equipment)...
OG triple OG
Re: Installing takata harnneses to my roll cage?? (94eg!)
this is the first time i have heard this about length vs stretch... plus the stretch couldnt be signicant or it would defeat the purpose....
climb_on
13
05-08-2008 08:40 PM
VTEC_PRODUCTION
50
03-19-2008 07:49 AM
