aluminum equal length manifold
Old Aug 30, 2004 | 08:12 PM
redboost10's Avatar
Default aluminum equal length manifold
i see mcmaster has some schedule 40 aluminum pipe now, just wondering if anyone has messed around with it or will it even stand up? schedule 40 is like 8 guage. what do you guys think?
Old Aug 30, 2004 | 08:18 PM
mmuller's Avatar
Mad Scientist
Default Re: aluminum equal length manifold (tgh99si)
what as in ex. manifold?
no it wont work
Old Aug 30, 2004 | 08:38 PM
redboost10's Avatar
Default Re: aluminum equal length manifold (mmuller)
yeah sorry, i meant like a turbo manifold, can you expalin why it wont work, im not too familiar with scheduel 40 aluminum?
Old Aug 30, 2004 | 08:45 PM
Civic92Turbo's Avatar
all aluminum will melt and dissipate at the levels of heat the exhaust produces. Thats why most exhaust are made from mild steel, stainless steel, icolenel or cast iron.
Old Aug 30, 2004 | 09:31 PM
redboost10's Avatar
Default Re: aluminum equal length manifold (Civic92Turbo)
alright, thank you, i knew aluminum would melt at high heats, but i wasnt sure about a thicker aluminum, if it would work or not. thank you for the info
Old Aug 30, 2004 | 10:37 PM
Ekasey's Avatar
aluminum isn't inteded for high heat.
At elevated temeratures, the material will break down crack and eventually erode away
Old Aug 31, 2004 | 06:31 AM
pete98m3's Avatar
in an exhaust... it wouldn't break down and crack... it'd straight up melt.
melting point of aluminum is approx 1215dF... egts : 1400-1700 dF
i'm using some of that aluminum tubing to make a short runner intake. You however can get it cheaper from http://www.onlinemetals.com
Old Aug 31, 2004 | 03:07 PM
redboost10's Avatar
Default Re: (pete98m3)
thanks for all the melting point numbers. those are interesting. i was just really curious about using schedule 40 aluminum for a turbo manifold cause i know that would be very light but i wasnt sure if that thick of aluminum would work or would it be just like any other aluminum. thanks guys.
Old Aug 31, 2004 | 03:37 PM
david@didrace.com's Avatar
Default Re: (tgh99si)
1220.666 °F is 1220.666 °F. It doesn't matter if it's thick or thin, once it hits the melting point it is going to melt.
- Aluminum is evil. *.666 °F
Old Aug 31, 2004 | 11:55 PM
tekstyle's Avatar
heat conductivity rate of aluminum is a **** load higher than that of steel. if your manifold doesn't melt, it will start to crack from the stress of cooling down and heating up from driving... and then fall apart
RO_SUNNY
Welding / Fabrication
Jul 19, 2011 12:55 PM
curtie94
Mar 24, 2011 08:56 PM
mister2racer
Oct 30, 2004 11:44 PM
FOrSfEd
May 7, 2004 06:59 AM
Heath
Jan 30, 2003 08:08 AM
