dash, power windows,& sun roof quit
Old Aug 30, 2004 | 03:01 PM
ultraforce77's Avatar
Default dash, power windows,& sun roof quit
alright once again my car has gone stupid. i had a problem before and fixed it my changing the alternator. and everything was working fine bother rpm and speedometer were working, and it was stating up again. this time the rpms stop reading and the speedometer stopped reading, my power windows wont go back up and my sun roof won't come back in. my car starts this time but the difference this time is the all dash is out! clock nothing lights up except the battery light, but its not the battery b/c my car starts up fine. i'm not sure if it overheats b/c i couldn't read it but the fan cam on very fast and i dont think it has done that before. any help would be awesome! i really need a helms manual
Old Aug 30, 2004 | 03:07 PM
eLUDEnu
Guest
Posts: n/a
Default Re: dash, power windows,& sun roof quit (ultraforce77)
try checking your fuses
Old Aug 30, 2004 | 03:09 PM
Default Re: dash, power windows,& sun roof quit (eLUDEnu)
already did nothings wrong
Old Aug 30, 2004 | 03:44 PM
Skidtron89's Avatar
You have to have bad fuses or the wiring is destroyer to a point that it severed itself. Thats the only choices so get in there and look again at the fuses. Since I'm sure you don't smell burt wiring or you would have mentioned it in the post. Sometimes you have to pull the fuses to be able to see if they are blown or not. You can't just glance. You need to be looking at the big fuses not teh little ones btw. It could be the little ones but if you were having alternator problems it would have blown one or two of the bigger main fuses
Old Aug 30, 2004 | 05:58 PM
Default Re: dash, power windows,& sun roof quit (Skidtron89)
hey man i went back and checked them again and it was a blown fuse. go figure it was the meter one. it wassn't cut completely but deff didn't look right which would explain y it would work for a lil bit and then didn't must have arched in it or something. well anyway thanx again my car is working again
95civicproject
24
Oct 17, 2011 01:52 PM
Goldenls
Apr 8, 2010 11:09 PM
JayJay99
19
Apr 11, 2009 04:43 AM
spoonracer84eg
20
Apr 26, 2006 02:27 PM
98civic94gsr
May 2, 2005 04:40 AM
