Wiring Guru's need some help
Alright I got a 1989 honda civic lx with a draw. If you let the car sit overnight the battery will be totally dead in the morning. I know the battery is good and the alternator is good.
I went through the fuse panel with a voltmeter, I believe is what its called, with it set at 20 dcv. The fuses that had juice running through them are:
power door locks: 11.35
Clock/interior light/cig lighter: 11.35
12V NO RC 2203 Mitsuba 805(doesn't look any of the other fuses, four pronged, big and black): 12.6
Underneath the hood
Hazards: 11.5
Stop horn: .11
What I am wondering is if all of these different things should be drawing power with the key off.
For the time being I have a switch rigged up to stop power from going through the car and I am getting sick of it and want the problem fixed.
Thanks,
98civic94gsr
Underneath the hood
Hazards: 11.5
Stop horn: .11
Thanks,
98civic94gsr
if it drawing power, it should have a battery light turn on when u turn it off, unless u kill your switch. I think that it might be u got 2 wires touching. check out all the wiring that distributes electricity and go from there
Re: (turbo_b16_ex)
I know that it is probably two wires touching somewhere. Shorts are always so hard to find.
I did just buy the car and when I first got it I drove it everyday and started it quite a bit so I didn't have the problem. Now my gf drives it and not nearly as much as as I did.
I'm wondering what the black fuse is? Any ideas?
Thanks
Thanks
rewerbcrx
14
08-16-2007 11:42 PM
GoLowDrew
01-09-2002 06:24 AM
