Question about Vacuum Ports at Intake Manifold
Old Aug 30, 2004 | 08:35 AM
mrx's Avatar
mrx
Default Question about Vacuum Ports at Intake Manifold
Hallo,
i have a question concerning the vacuum ports on the stock B16A1 intake manifold.
does it make any difference in vacuum and boost readings if i connect my map sensor to one of the vacuum ports on the back of the intake manifold (near cyl. 1), on the middle on direct after the throttle body (near Cyl. 4) or if i connect the map sensor to one of the two vacuum ports directly at the throttle body where it is also connected on the stock setup for NA engine?
i ask because i'am not sure if my map sensor ready full boost because under full boost i must get something around 4,52volt but i read only something about 3volt on 8psi of boost so its not enough i think...
and before everyone ask, i'am running a standalone ecu that can handle MAP Sensor signals from 0-5v its only a question if the pressure is different on the different vacuum connectors on the intake manifold.
Greets
Malte.
Old Aug 30, 2004 | 08:40 AM
DaX's Avatar
DaX
Loved
Community Favorite
Possibly slight variations, but it really shouldn't matter which nipple you use.
JDMEMone
Engine Management and Tuning
Dec 10, 2014 06:26 AM
egjdmcivichatch
Mar 2, 2010 12:38 PM
88 rex
Aug 16, 2005 06:49 PM
fast93accord
May 23, 2005 09:31 AM
zippeay
Aug 8, 2003 02:25 PM
