Oil leak...Help!!
Old Dec 5, 2001 | 07:58 AM
JSpecwest's Avatar
New User
Default Oil leak...Help!!
I finally got my motor back last night. For those that didn't know I blew my piston rings so I had new stock pistons, bearings, rings, etc. installed by a professional shop. We got the motor in, cranked it over to build oil pressure, then started it. It ran good for about 3 seconds and then I started to hear a bubbling noise. I looked in the motor and saw oil spewing out of the back of the head where it meets the block. It was really hard to see where it was coming from but Im pretty sure it was coming from this area. I supplied a brand new head gasket for the shop, and you can see it so I know they installed it. There is only one way to put it on (unless you are a total idiot) so I know that can't be the problem. The only thing I can think of is that they didn't torque the head bolts but they insist that they did and it is only leaking out the back. Were not talking about a little oil here. It made a lake in my driveway. What else could it be? The shop was saying something about an oil sensor. They can't get it in till Friday. Help anyone?
Old Dec 5, 2001 | 08:09 AM
yoshi234's Avatar
I shoot brides
Default Re: Oil leak...Help!! (JSpecwest)
did you check the oil filter?
Old Dec 5, 2001 | 08:10 AM
JSpecwest's Avatar
New User
Default Re: Oil leak...Help!! (yoshi234)
Yep...there is no oil on the outside of the filter and its on tight.
Old Dec 5, 2001 | 08:16 AM
B18CXr's Avatar
most likely they installed the headgasket wrong...
or wrong PN on the gasket
[Modified by B18CXr, 12:16 PM 12/5/2001]
Old Dec 5, 2001 | 08:19 AM
JSpecwest's Avatar
New User
Default Re: Oil leak...Help!! (B18CXr)
Wouldnt it leak out the front then also?
Old Dec 5, 2001 | 08:22 AM
B18CXr's Avatar
not if the oil passage for the vtec is blocked for one reason or another....
Old Dec 10, 2001 | 09:31 AM
JSpecwest's Avatar
New User
Ok the shop says the oil is coming from the back of the block, not from the head. They still havent attempted to figure what is wrong. They said something about a dolley plug? Are there any plugs on the back of the block?
Old Dec 10, 2001 | 09:57 AM
98TypeR's Avatar
my bet is they didn't torque the head properlly. I had that same problem when i made that mistake. but mine dumped 4 quarts of oil in about 45 seconds. I'm a dumbshit.
Old Dec 11, 2001 | 08:38 AM
JSpecwest's Avatar
New User
Default Re: Oil leak...Help!! (98TypeR)
They finally figured out that the headgasket didn't seat properly. Picking up the car today, its been a few months since Ive hit VTEC. Cant wait...
Old Dec 11, 2001 | 08:40 AM
sackdz's Avatar
Ewww messy
Old Dec 11, 2001 | 08:44 AM
Brian's Avatar
So does that secretely mean they put the headgasket on wrong?
Old Dec 11, 2001 | 08:46 AM
JSpecwest's Avatar
New User
Default Re: Oil leak...Help!! (QuickType-R)
Ahh these damn mullet shops...we need a good import shop in Vancouver, WA.
Old Dec 11, 2001 | 11:32 AM
JSpecwest's Avatar
New User
Default Re: Oil leak...Help!! (sackdz)
Just got back from hitting vtec a few times. The car feels smooth. New bearings, pistons, rings, valve adjustment, mobil one synthetic, new exedy clutch. The R is back!
Old Dec 11, 2001 | 12:11 PM
fast-R's Avatar
New User
what shop did you go to? just out of curiosity. Glad to hear you figured out the problem.
Old Dec 11, 2001 | 01:08 PM
B2FiNiTY's Avatar
Good to hear.
Old Dec 12, 2001 | 02:37 PM
RJL's Avatar
RJL
New User
Default Re: Oil leak...Help!! (B2FiNiTY)
broke in new pistons, rings and bearings with synthetic oil? You should have used regular oil for the first 1000 miles. I just had my whole bottom end built up. and thats what I was told I neeeded to do, no reving past 7000. But then again it might not make a difference
Old Dec 12, 2001 | 02:41 PM
RedlinedVTEC's Avatar
Did you break the motor in or are you already revving the **** out of it before 1000 miles? If so it won't be long till the next rebuild.
Old Dec 12, 2001 | 04:15 PM
fsarfino's Avatar
Default Re: Oil leak...Help!! (RedlinedVTEC)
thats why you should do all your own work
Old Dec 12, 2001 | 06:10 PM
JSIR's Avatar
New User
Default Re: Oil leak...Help!! (dohcvtec16)
it doesn't take much to get a Honda head gasket to seat properly, if installed right on a clean block and head and torqued properly they work every time. They installed the head gasket upside down and that leads to instantaneous leakage every time !, no doubt about it. I hope they didn't charge you for the second head gasket and related work.
Joey
Old Dec 12, 2001 | 07:03 PM
Mike K's Avatar
you're joking, right?
atta boy! beat on it right away. see how the compression test looks in a few thousand miles with that oil, too.
Old Dec 13, 2001 | 07:57 AM
Hooch'n's Avatar
Default Re: Oil leak...Help!! (Mike K)
...don't kill the car right away. You just got it back.
Make sure you keep an eye on that spot.......if oil comes out while you are driving...
[Modified by 8400-RPM, 4:57 PM 12/13/2001]
92redhatch
Aug 27, 2006 09:52 AM
premo_si
Aug 2, 2006 08:56 AM
Screaminz28
Oct 16, 2002 11:35 AM
JSpecwest
Jan 8, 2002 04:02 PM
JSpecwest
Dec 7, 2001 12:49 AM
