Engine temperature
Old Aug 29, 2004 | 02:08 PM
85civic's Avatar
Default Engine temperature
I just recently bought up a civic, I noticed it seemed to be running a little hot. (the temperature gague was 3/4) Today I drained the fluid flushed it and refilled it and it still runs at the same temperature. Any suggestions on what I should do? or should I worry about it running that hot?
Old Aug 29, 2004 | 02:31 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Engine temperature (85civic)
replace thermostat
Old Aug 29, 2004 | 02:40 PM
eda6's Avatar
Replace T-stat and radiator cap. Check fans, head gasket and water pump. If you're constantly adding coolant it's the head gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 85civic &raquo;</TD></TR><TR><TD CLASS="quote"> should I worry about it running that hot?</TD></TR></TABLE>
I finished off my 85 one day due to overheating. The head gasket blew on the freeway. White smoke followed by loss of power. Those motors "diesel" when they're too hot (attempt to idle when it should be off). The only way to stop it is to put it in gear and make it stall. I hope it doesn't come to that.
Old Aug 29, 2004 | 02:45 PM
85civic's Avatar
Default Re: Engine temperature (eda6 hb)
Alright I guss I will replace the thermostat and radiator cap and see what happens, thanks for the advice.
Old Aug 29, 2004 | 03:21 PM
Reason's Avatar
Is your radiator rusted all out. It might not be flowing like its suppose to.
D3vin
14
Mar 14, 2010 08:41 PM
kte324
Oct 26, 2009 04:37 PM
Extreez
Mar 14, 2007 03:44 PM
4theluvofhonda
15
Jan 21, 2007 05:00 PM
extrmeboost
Jul 15, 2003 07:42 AM
