watercooled turbo
Old Aug 29, 2004 | 03:15 AM
RACEPAK's Avatar
Default watercooled turbo
hello everybody
i have a oil/water cooled turbo.
my question: where to i need to tap coolant in/out?
best regards moshik
Old Aug 29, 2004 | 04:33 AM
93turbo16's Avatar
Its been done, just use the search button. BUt I guess I will give you a tip, just make a loop with one of your TB or IM colant hooses. Not hard to do at all, takes about 5 minutes to do if that.
Old Aug 29, 2004 | 04:55 AM
USDM 4G VTEC's Avatar
Default Re: watercooled turbo (RACEPAK)
i have a D16Z6 with Y8 intake manifofld
i tapped the inlet for coolant to a TB line.. i Tee it to there
then the back of the block has a nipple by the water pump, i piut the return line there, so the vacumm of thepump will keep the coolant flow thru the turbo
Old Aug 29, 2004 | 06:22 AM
RACEPAK's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i have a D16Z6 with Y8 intake manifofld
then the back of the block has a nipple by the water pump, i piut the return line there, so the vacumm of thepump will keep the coolant flow thru the turbo</TD></TR></TABLE>
do you have a picture of your setup ?
can any body plesase post a pictures of the places i need to tAP INTO?
Old Aug 29, 2004 | 07:08 AM
delslowh23's Avatar
Default Re: (RACEPAK)
i just put a tee in the heater hoses
if you need pic let me know
Old Aug 29, 2004 | 11:23 AM
RACEPAK's Avatar
Default Re: (delslowh23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslowh23 &raquo;</TD></TR><TR><TD CLASS="quote">
if you need pic let me know</TD></TR></TABLE>
please if its not too complicated.
Rubixcu7
Jul 11, 2005 08:27 PM
Civicman86
Jan 31, 2005 08:47 AM
hatchracer02
Jan 24, 2005 08:14 AM
soundman
Apr 22, 2003 08:27 AM
SiRkid
Nov 3, 2002 07:45 PM
