i read the faq...can't seem to figure out how to get the engines code....
ok so i jsut picked up my lude...the check engine light is always on...i have DC headers full 2'1/4 cat back with CAT so all sensors are there etc....
AEM cold air and VAFC...
now i used to have a VAFC on my turbo teg and it would through some MAP codes at me once and a while so i would jsut turn the key on and off and it would be fine...now somtimes on my lude the cutt off is at 7000RPM and when Vtec engages its like i lose power...now if i reset by turning the key on and off...it comes back to normal having good power in vtec and shifting @ ~ 8200RPM.....BUT the stupid light stays on even though i reset....
so i tried gettign the codes and a mecanic budy of mine told me that the green little connector is on the helper side.. i checked and actually found on jsut like it but on the driver side...so i tried to check the codes but all it does is beep once or twice and no flashes occur....could someone help me...sorry for the lenth..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg969 »</TD></TR><TR><TD CLASS="quote">ok so i jsut picked up my lude...the check engine light is always on...i have DC headers full 2'1/4 cat back with CAT so all sensors are there etc....
so i tried gettign the codes and a mecanic budy of mine told me that the green little connector is on the helper side.. i checked and actually found on jsut like it but on the driver side...so i tried to check the codes but all it does is beep once or twice and no flashes occur....could someone help me...sorry for the lenth..</TD></TR></TABLE>
http://www.92lude.com/diagnose_error_codes.htm
crapp...i jsut got the code...its code 22 Vtec system malfunction
i take it that it's maybe my VAFC that makes this happen anyone else ever experience this...thx
I have a 98 honda prelude and my check engine light is always on as well.. my code is p1259 vtec malfunction, online i looked around and found p1259 code is also " vtec solenoid or switch circuit ( rear- bank 1) "
Not sure what this means...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg969 »</TD></TR><TR><TD CLASS="quote">crapp...i jsut got the code...its code 22 Vtec system malfunction
i take it that it's maybe my VAFC that makes this happen anyone else ever experience this...thx</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=830163
take alook at this FAQ thread
i take it that it's maybe my VAFC that makes this happen anyone else ever experience this...thx</TD></TR></TABLE>https://honda-tech.com/zerothread?id=830163
sagron69
11
Mar 19, 2004 06:51 PM
