non equal length manifold?
Old Aug 27, 2004 | 06:07 PM
b16hybridsol's Avatar
Default non equal length manifold?
what would happen if you over exaggerated a cast mani. Say for example you make the #2 and 3 cylinders 6" long. And you make the #1 and 4 cylinders 12" long. Would this just cause unequal air flow in the cylinders and fry the motor, or could it possibly give you the benefits of both sides (faster spool, with a little more top end than a log style). Just an idea, i'm thinking it would cause the #1,4 to run lean, but i didn't see anything when i searched, and its a question worth asking
Old Aug 28, 2004 | 10:28 AM
Default Re: non equal length manifold? (b16hybridsol)
yes, no? i'm about to jut try it and find out
Old Aug 28, 2004 | 02:22 PM
SJcivic's Avatar
The point of having equal length runners is to get a sudden exhaust charge to spool up the turbo quickly, then wait for the next pulse and have them equally spaced. Smoother (i guess)
Tuned length manifolds are (from what I undertstand) mate 2 or more exhaust pulses together in order to make a harsher spool, but with more 'lag time' in between. not as smooth (I guess)
Then theres the convo. about 4-1 or 4-2-1 manifolds and that just gets more complicated.
Rich
Old Aug 28, 2004 | 04:00 PM
Default Re: non equal length manifold? (SJcivic)
aahh i see
Old Aug 28, 2004 | 07:49 PM
SJcivic's Avatar
Relavent link:
http://www.burnsstainless.com/....html
Rich
Old Sep 1, 2004 | 08:56 PM
Honda-Pilot's Avatar
Another factor to consider is that a longer pipe will have more of a restriction than a shorter pipe giving unequal afr's per cyl.
Old Sep 1, 2004 | 11:20 PM
SJcivic's Avatar
Default Re: non equal length manifold? (Honda-Pilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Pilot &raquo;</TD></TR><TR><TD CLASS="quote">Another factor to consider is that a longer pipe will have more of a restriction than a shorter pipe giving unequal afr's per cyl.</TD></TR></TABLE>
Yes and we can go into how a longer runner means a cooler gas, therfor means a slower flow, but that is best left until later.
Rich
Old Sep 1, 2004 | 11:41 PM
i had the general points established,but thanks for clearing some of the stuff up guys. i was really more focused on the tuned length manifolds. to bad each cylinder can;t be tuned by itself, or some crazy **** would probably be going down
Old Sep 2, 2004 | 11:40 AM
SJcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">to bad each cylinder can;t be tuned by itself, or some crazy **** would probably be going down</TD></TR></TABLE>
Any real stand-alone EMS can do this easily. Individual cylinder mapping has been around a while.
Rich
Records
Mar 2, 2012 04:32 AM
ashtons300zx
Dec 8, 2011 07:28 AM
85
Jul 24, 2009 02:53 PM
Civic TSI
Jun 22, 2001 10:24 AM
