Timing question??
Old Aug 27, 2004 | 04:02 PM
Inspector Gadget's Avatar
Default Timing question??
I decided to check the timing on my 1992 civic vx. The middle red mark which is 16 degrees TDC is no where near the mark on the timing cover, it's more towards the front of the car. I adjusted the distributer forward and it gets closer, so i adjusted it again, and again till i cant go any further and the 16 degrees TDC mark still wont get any closer to the the timing cover mark. I have no idea what to do. Any help will be appreciated.
Sorry if you dont understand, I explained the best i could. Thanks in advance.
Old Aug 27, 2004 | 04:06 PM
Lord Helmet's Avatar
Default Re: Timing question?? (Shit_Bam)
yourcamshaft timing or crankshaft pulley is off. get it aligned up before you use the timing gun again.
Old Aug 27, 2004 | 04:07 PM
Default Re: Timing question?? (sleeperciv)
how do i do that?
Old Aug 27, 2004 | 04:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shit_Bam &raquo;</TD></TR><TR><TD CLASS="quote">how do i do that?</TD></TR></TABLE>
set the engine to TDC on cylinder #1. the crankshaft pulley should have a white mark on it (not the 3 red marks that are together). it should line up with timing belt plastic cover pointer and also the camshaft pulley should have the "UP" symbol facing upward with both lines perfectlly aligned with the block. that applies to the VX engines. the EX engine requires you to have the lower line (the one that points to 7 o'clock) aligned to a pointer that is on the timing cover.
if they are not perfectlly aligned you need to get them align.
Old Aug 27, 2004 | 04:21 PM
Thanks man, I'll go try that. After i do that I will be able to check the timing correct?
Old Aug 27, 2004 | 04:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shit_Bam &raquo;</TD></TR><TR><TD CLASS="quote">Thanks man, I'll go try that. After i do that I will be able to check the timing correct?</TD></TR></TABLE>
once you get the camshaft and crankshaft pulley properly aligned and you have the engine warmed up to the normal level( fan goes on twice, jumped the 2 wire connector) you can finally do a proper timing adjustment. if it is aligned properly you shouldn't have any problems since the white mark will line up with the pointer when the engine is at idle. then once you advance it to 16 degrees TDC, it should line up with the middle red mark. that is 16 degree TDC. if it is off then play with the distributor a little bit and it should line up perfectlly.
Old Aug 27, 2004 | 04:38 PM
Do i need to buy something to just the 2 wire connecter?
Old Aug 27, 2004 | 04:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shit_Bam &raquo;</TD></TR><TR><TD CLASS="quote">Do i need to buy something to just the 2 wire connecter?</TD></TR></TABLE>
no, you can use 18 gauge speaker wires. just make sure it's small enough to fit in the connector.
Old Aug 27, 2004 | 04:50 PM
Thanks for your help man, but it is still messed up. I'm going to wait for my buddy to get home who has done this before. Thanks again.
Old Aug 27, 2004 | 05:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shit_Bam &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for your help man, but it is still messed up. I'm going to wait for my buddy to get home who has done this before. Thanks again.</TD></TR></TABLE>
no problem
ukrkoz
23
May 24, 2009 04:26 PM
z6hatchboy
13
Dec 24, 2007 01:19 PM
dsCRXsi
May 2, 2004 04:32 AM
Lei Siew Long
Mar 31, 2004 12:43 PM
Brian_92GSR
Aug 19, 2002 07:23 AM
