Rear disc conversion...will 1990 integra work?
Old Aug 27, 2004 | 09:43 AM
unknown0001's Avatar
Default Rear disc conversion...will 1990 integra work?
Hey guys, I have a 94 civic coupe si and it has drum brakes in the rear.
I have a friend that is parting out his 1990 acura integra and it has rear discs.
Would I be able to use those rear brakes off the integra and set it up on my civic??
I tried searching but couldn't find anything for 1990 integra brakes
thanks
Old Aug 27, 2004 | 09:57 AM
hatchi's Avatar
Default Re: Rear disc conversion...will 1990 integra work? (Mr.RHTuner)
yes you can just change ebrake cables. but i believe you can use those ebrake cables.
Old Aug 27, 2004 | 10:00 AM
Default Re: Rear disc conversion...will 1990 integra work? (hatchi)
is this a hard swap???
I've never done a swap like this.
So all I do is bolt up the whole rear suspension?
Do I have to run brake lines and stuff like that?
thanks again
Edit:
also is there any difference between the EG rear shocks and the DA rear shocks???
Old Aug 27, 2004 | 11:26 AM
SkoundrelUSA's Avatar
cute little bastard
Take everything you can off the integra: Trailing arm, control arms, rotors, calipers, e-brake cables (im 99% positive you cant use your own). Make sure you have all the bolts and nuts for everything. Bolts for calipers, pins for the e-brake cables. The guy I bought if off in NJ named Sal ripped me off and that **** was such a headache. Also if you're looking for better braking power, take the brake booster and master cylinder (if they are 15/16) and 40/40 proportioning valve from the teg too. After that stainless steel lines. Am I missing anything?
Old Aug 27, 2004 | 01:37 PM
bump
Old Aug 27, 2004 | 01:43 PM
s.patel's Avatar
u sure its an si, cuz si's only came in a hatchback model in that generation, and also the si comes standard with four wheel disk....
Old Aug 27, 2004 | 08:40 PM
Default Re: Rear disc conversion...will 1990 integra work? (s.patel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s.patel &raquo;</TD></TR><TR><TD CLASS="quote">u sure its an si, cuz si's only came in a hatchback model in that generation, and also the si comes standard with four wheel disk.... </TD></TR></TABLE>
Yes I have an Si....CDN model..so I belive it's EX in the us.
I have all the Si goodies and I know for a fact because of papers.
Old Aug 27, 2004 | 08:56 PM
spock_rocker's Avatar
memoryFAB.com representative
i didn't know that a 90 integra rear discs would work with an EG???!!?? can someone confirm this please?
Old Aug 27, 2004 | 08:58 PM
s.patel's Avatar
coo, i wasn't trying to flame or anything.....good luck w/ the swap.....
Old Aug 27, 2004 | 09:01 PM
pdiggitydogg's Avatar
Default Re: Rear disc conversion...will 1990 integra work? (spock_rocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">i didn't know that a 90 integra rear discs would work with an EG???!!?? can someone confirm this please?</TD></TR></TABLE>
I know a guy that has them
I had them bolted on my ek
Old Aug 27, 2004 | 09:54 PM
Default Re: Rear disc conversion...will 1990 integra work? (pdiggitydogg)
anyone else.. i know i can get some at a junk yard for cheap!!
Old Aug 27, 2004 | 09:58 PM
Ransom's Avatar
Damn i thought the 90-93 integra rear disc wouldnt work...I had a complete car in my backyard that i could have ripped it off and put on my civic...But its junked now...Boo for me not knowing
Old Aug 27, 2004 | 10:02 PM
Default Re: Rear disc conversion...will 1990 integra work? (LudeSH)
ok...well I came across 94+ GS-R conversion. If the guy won't take what I offer I'll be getting the 90' integra disk conversion
dammit I hope this works
Old Aug 30, 2004 | 08:56 PM
jdmsiR20's Avatar
somebody help him out (and me too in the process)
confirmation.... please!
Old Aug 30, 2004 | 09:00 PM
Andres-eh2's Avatar
yes it does work. you gotta keep the civic LCA and upper control arm as well as the toe adjuster
JDM_NANO
Northeast (Sales)
Oct 12, 2011 06:57 AM
wlp2nd
Suspension & Brakes
Nov 2, 2009 03:14 PM
94-integra-ls
Oct 15, 2009 04:22 PM
GserpleaSR
Aug 30, 2006 06:11 PM
damn_import_culture
Jan 1, 2005 01:07 AM
